GS300 - Accelerating on its own
Old 01-21-15, 10:23 AM
GS350Lexus
GS350Lexus's Avatar
Originally Posted by sam12345
You guys are all delusional. Lexus is perfectly normal like any other car on this subject. Maybe you guys need to learn how to drive. All cars idle faster when cold. I remember the days of carburetors. Back then you could hit thirty without touching the gas when the car was cold.
Maybe you need to drive other cars like BMW, NISSAN, ACURA, FORD etc etc where the car idle high for the first 30 seconds, not until NORMAL OPERATING TEMPERATURE which takes 3-5 minutes depending on how cold it is.
Old 01-21-15, 05:38 PM
Gotcha350
Gotcha350's Avatar
It depends on the outside temperature. I have an Acura, Infiniti, and the GS...they all idle high for 3-4 mins when temps are around freezing...they will idle around 1300 for about 30 seconds and then drop to about 1100-1000. It because the ECM is programmed to run full trim to help warm the car up to reduce emissions as quickly as possible.
Old 01-21-15, 10:04 PM
sam12345
sam12345's Avatar
Are you arguing or empasizing my point because you are saying what I said it's normal to have a high idle when cold
Old 01-21-15, 10:52 PM
GS350Lexus
GS350Lexus's Avatar
As I said in earlier post, LEXUS idles high until normal operating temperature (take 3-6 minutes) depending on the temperature outside. Other cars I have owned and driven, will only idle high for the first 30 seconds. The issue is not the first 30 seconds of driving, its the annoying few minutes until it warms up. Every car idle high when cold started, some do it for about 30 seconds which i consider normal, Lexus won't drop to normal idle until it is FULLY warmed up which again can take few minutes and it is annoying driving those few minutes.
Old 01-22-15, 10:54 PM
BinaryJay
BinaryJay's Avatar
Bottom line: It's normal.
Next actions: Live with it, or buy a block heater.
End of thread.
thebes
09-09-17 06:05 PM
Nguyen255
Performance
20
04-19-16 10:11 PM
GeorgeG5
03-31-16 08:25 PM
99a6q
GS - 1st Gen (1993-1997)
05-03-10 05:54 PM
BinaryJay
11-11-09 04:47 PM
Quick Reply: GS300 - Accelerating on its own
