2007 Gs350 CEL-TRAC-CHECK VSC
I need some advice quickly.
On my 2007 Gs350, I have CEL, CHECK VSC, AND TRAC lights on. I read numerous issues of what it could be.
I wanted your guys opinion.
My front right shock is bent sight and I know this because my wheel is tilted inward, also I think the left one needs to be replaced. I did order two new shocks.
I'm curious as to, could this be the reason that it's throwing the lights on?
Well how do you know the shock is bent? could be your upper or lower control arms might be bent. Did you hit a curb or something? the light could be being thrown because of the abs sensor being out of whack or your speed sensor.
The previous owner that I bought it from told me that it's bent. Also the reason I think it's throwing the light is because a friend of mine has a gs350 also and when he put coil overs on it without camber kits, the same situation happened to him.
Most people who had this issue had the same codes coming up but I will do a complete system check once i replace the struts and can drive to a near by autozone
mobthani
04-25-20 07:45 AM
