08 GS350 has noise after CHANGED WITH THE new OEM rotor and brake pads.
Old 11-13-14, 06:53 AM
janmy7
janmy7's Avatar
Default 08 GS350 has noise after CHANGED WITH THE new OEM rotor and brake pads.
I changed my front rotor and brake pad with the oem parts last week.
However, it has noise come out everytime when I touch the brake.
Is it normall? Or does it need times for break down?
Or I did something wrong in installing that cost the noise?
Anyone has this expericence?
Old 11-13-14, 06:58 AM
Gotcha350
Gotcha350's Avatar
Did you clean the rotor well before installing them and use the new shim pads for the the brakes? I've never had that happen with me and im on my 3rd set of rotors and OEM pads nad have never had a noise issue.
Old 11-13-14, 07:06 AM
janmy7
janmy7's Avatar
I saw the guy use some spray to clean the rotor once.
I changed my rear one before but had no noise issue too.
It's weird.
Old 11-13-14, 07:10 AM
Gotcha350
Gotcha350's Avatar
It's weird.
If you had someone do they work I would definitely take it back and let them hear the noise and look at it.
Old 11-13-14, 03:06 PM
pman6
pman6's Avatar
what noise? squealing ?
I have that on mine when I lightly apply brake. It's probably the shim, but i don't care anymore.
The brake noise serves as a warning to pedestrians
Old 11-13-14, 03:27 PM
jdmek998
jdmek998's Avatar
Were they bedded correctly? That might cause a little squealing. Or maybe they to be glazed. If a shop did it then take it back.
Old 11-14-14, 07:28 PM
Asav
Asav's Avatar
What he said. Your brakes are nod bed in correctly. Do that and you will be good provided the install was done properly. Procedures for bedding are all over this site in various places.
Old 11-15-14, 05:29 AM
Ironman50
Ironman50's Avatar
I had same problem on my 2008.
Took it back to Lexus dealership after the brake service - they replaced it no questions - something about a defective shim part problem that Lexus was aware of.
Old 11-16-14, 01:32 PM
janmy7
janmy7's Avatar
just found another issue. there are lots of dust from the brake pad on the wheel after one week used. the oem part that sucks? the guy told me that some after market brake pad sold by autozone is better than the oem toyota parts.
Old 11-16-14, 02:59 PM
vincewchan
vincewchan's Avatar
Did you order the low dust brake pads? Part number is 04465-30450.
I've heard a lot about the OEM (non low dust) brake pads giving off a lot of dirt/debris. That could be it.
Old 11-18-14, 08:16 AM
janmy7
janmy7's Avatar
No, they gave me the 0446530500. Is it not the same?
Old 11-18-14, 09:04 AM
Gotcha350
Gotcha350's Avatar
The OEM pads don't suck...they are just aggressive, wear faster, and give off more dust. I have had both with new rotors and can say that the car stopped better to me with the hi dust OEM pads but the dust was almost unbearable. So now I have gone back to the low dust pads and they are a lot easier on the rotors as well.
Old 11-19-14, 12:17 AM
sr20mofo
sr20mofo's Avatar
if u went with OEM pads... then they are known to noises and lots of dust
just bought my car and dealer put on new oem rotors and pads, changing them out to akebono pro act
anyone need new front and rear brake pads for cheap? lol
Old 11-20-14, 06:58 PM
Asav
Asav's Avatar
I agree. That's why I went with the akebono pads. The dust was killing me and they stop the car just fine so it works. I don't want to eat rotors nor do i want to clean wheel dust off daily.
20012003rx
RX - 1st Gen (1999-2003)
06-01-15 09:34 AM
FMA08ISF
IS F (2008-2014)
06-29-14 07:22 PM
seivonecsu
Suspension and Brakes
03-08-12 11:10 PM
valgs350
12-15-07 11:35 PM
URDONE
07-09-07 09:32 AM
Quick Reply: 08 GS350 has noise after CHANGED WITH THE new OEM rotor and brake pads.
