Question on wheel spacers
Old 09-27-14, 08:50 AM
doctordank
doctordank's Avatar
Default Question on wheel spacers
So I've seen some negatives on spacers, mainly in relation to the bolts not being as durable as oem and breaking. I know most that use them are doing it to widen wheel stance, anywhere from 3mm to 30mm+. My issue is the new wheels I bought clear calipers while driving straight and turns are ok, but when I brake into turns, I can hear it clipping calipers. I was planning on getting just a 3mm spacer disc, without the stud bolts, to give it a bit more clearance. Any concerns using them? Seems most negatives are on the bolts. TIA for any feedback.
Old 09-28-14, 11:59 AM
designo
designo's Avatar
I would avoid them not cause they are not safe, but cause for our cars ( studs ), they cause wheel wobble.
Having said that, anything less than 10mm you're safe as they come with extended studs so no difference to OEM safety!
Old 09-29-14, 10:56 AM
doctordank
doctordank's Avatar
Thank you!
Old 09-29-14, 05:04 PM
LexLova
LexLova's Avatar
I use 15mm front 25mm rear. Works perfect, no wobble, shakes, nothing. Don't believe alot of the stuff you "Hear". Just make sure the spacers are hubcentric and come with built in studs. The extended stud style spacer is where trouble lies
Old 09-29-14, 09:25 PM
doctordank
doctordank's Avatar
Cool, what brand are you using?
Old 09-29-14, 11:21 PM
angus
angus's Avatar
It should be noted that with a 3mm spacer you will not lose the original wheel hub "register" and that means you will still be hub centric and thus have no wobble or vibration issues.
You can use just about any 3mm spacers on the market - not much difference.
Old 09-30-14, 10:02 AM
designo
designo's Avatar
I have used 25mm with built in studs on OEM wheels = wobble
I have used 20mm with built in studs on OEM wheels = wobble
I have used 10mm with extended studs on 19" wheels = wobble
On all instances I removed the spacers and car ran smooth as butter. I am now running my 19" with no spacers and I'm great!
NOTE: All spacers were Ichiba brand and installed by local Lexus Dealer.
isfvss
IS F (2008-2014)
27
10-05-16 06:08 PM
shoney
17
04-18-16 05:17 PM
Jzsicklexi
07-20-12 06:05 PM
BennyJ
05-03-10 09:56 PM
BLK13X
Wheels, Tires & Brakes Forum
09-04-07 07:06 PM
Quick Reply: Question on wheel spacers
