Go Back   Club Lexus Forums > Lexus Model Forums > GS Models > GS - Third Generation
Sign in using an external account
Register Forgot Password?
Electric Power Steering Ecu
Thread Tools Search this Thread Display Modes
Old 08-13-14, 11:57 PM   #1
madcap
Trader Score: (0)
Default Electric Power Steering Ecu
WELCOME.
I have a problem with electric power steering in the Lexus GS300 2006.
System indicator does not light up even in the moments after ignition, fuses are OK. Where is the power steering module ?? I looked next to the brake pedal but it is not there
Help
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
madcap is offline   Reply With Quote
Old 08-14-14, 08:25 PM   #2
LEXPOS
Trader Score: (0)
LEXPOS's Avatar
I Im having the same problem with mine right now too. think is located on top passerger side on dash but if replace it i think you have to activate according to the dealer I think its BS but not sure if tru though. I got to pay 1030 $ to fix it.
LEXPOS is offline   Reply With Quote
Old 08-15-14, 02:58 AM   #3
IXI187IXI
Trader Score: (3)
IXI187IXI's Avatar
http://www.facebook.com/profile.php?id=100000548829927 AWD GS
i went through an issue a few years back and i recall it being in the engine bay, drivers side. i could be wrong though. my comp at work crashed and i lost all my lexus files
__________________
2006 Lexus GS 300 AWD Glacier Frost Mica - Black - ML Package
20" x 8.5" Status Knight Wheels Black with Machine Face | Bridgestone G-Force Tires 245/30/20 | BC Racing Coilovers | Carson Tuned Lip Kit | 3000k HID Fogs | Prestigious Society Navi/DVD Override Kit | 15% Tint | Black Roof and Window Trim
IXI187IXI is offline   Reply With Quote
Old 08-15-14, 06:04 AM   #4
BinaryJay
Trader Score: (0)
The power steering ECU is located underneath the battery holder in the engine bay, you need to take the battery out and the battery tray and it should be right underneath. It should be held in place by three bolts, At least this is where alldata is telling me it is... but when I find a part that sounds related to power steering on parts sites, it shows something related to power steering under the passenger side dash so... I don't know, two different things perhaps?
It looks like there are two things "steering control ecu" and "power steering ecu"... so which one is bad?
__________________
http://i42.tinypic.com/30mmpe1.jpg
BinaryJay is offline   Reply With Quote
Old 08-15-14, 07:19 AM   #5
LEXPOS
Trader Score: (0)
LEXPOS's Avatar
WOW so there's two o god i cant believe this Is one power control and other for signal? Because the dealer tells me that its the Computer but I don't know to diagnose both internally.
"Madcap" how did you're steering system stop working? Let me tell you this my wife is pointing finger at me for car not working when I only re-calibrated the tire pressure on car.
Has anybody herd of this tire switch under the dash to have anything to do with the EPS?
Old 08-18-14, 11:31 AM   #6
PhantomV
Trader Score: (0)
PhantomV's Avatar
i just had a problem with mine but it was because my wire harness had gone bad. I was replacing my pre cat O2 sensor and i guess a wire broke somewhere on the harness. they are EXPENSIVE to replace. better off looking online at the OEM lexus parts if it goes bad.
PhantomV is offline   Reply With Quote
Old 08-25-14, 12:41 AM   #7
madcap
Trader Score: (0)
thanks for the reply
I found under the battery module is
Unfortunately, unless the ECU is damaged when the power is on line K, there is no voltage, CAN line on two of the four wires is 2.5 V
Similar Threads
Thread Thread Starter Forum Replies Last Post
sc400 electric power steering kolessc400 SC 400/300 5 09-19-14 11:19 AM
Electric Power Steering is Cumbersome rschaer IS - Second Generation 7 08-23-14 09:43 AM
Disabling the electric power steering Paoloveggi GS - Third Generation 3 10-21-12 04:15 PM
Simple (?) question about IS250 power steering JimKing IS - Second Generation 3 03-20-11 11:36 PM
Electric Power Steering Recall DrComputer GS - Third Generation 17 10-07-06 04:13 AM
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2015 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
