cell phone via blue tooth
Old 07-20-14, 11:17 AM
gs350trev
gs350trev's Avatar
Default cell phone via blue tooth
every time i pair my car to my cell it works great but when i turn off my car i have to pair my phone again... is that what everyone else has to do.... If you dont how to i pair it so it will stay paired...
Old 07-20-14, 10:53 PM
Mistahoo
Mistahoo's Avatar
It should auto pair. Mine takes a bit to pair when I get in. Make sure your Bluetooth setting on your phone is on auto connect
Old 07-21-14, 01:26 PM
gs350trev
gs350trev's Avatar
ya its a Iphone so its on or off i think... When i get in the car it says that it didnt connect to phone...
Old 02-22-21, 02:08 PM
bvshearz
bvshearz's Avatar
I have this same problem...kind of.. I have a Samsung Android phone...I just got this car handed down to me from the wife,so...
Every time I get in and turn the car on,it connects to the phone right away for blue tooth calls....but... so far EVERYTIME it only connects for calls only.
I have to go to my bluetooth setting on my phone,turn it off and then back on until it scans and connects to "Car Multimedia"
it pairs up right away,but, I think it should stay paired up with the phone for BOTH calls and music...can't understand why I need to re-pair it every time for music? Is this what everyone else has to do?
Old 02-22-21, 02:28 PM
mcomer
mcomer's Avatar
Simple stuff to check, get in the habit of turning your phone completely off, cold dark dead, once a week or so.
30 seconds will suffice, doesn't have to be daily or overnight, just cycle it periodically.
Your symptom might be created by having a second phone that is paired such as your brides New phone paired to
the car also. When you go out and fire up the car it reaches out and pairs...to her phone. A marriage saving technique
is to turn off the Bluetooth of her phone briefly when you start the car.
When you initially paired the Android phone you would have seen a couple of dialog boxes open and ask permission
to transfer contacts and allow for auto pairing. If you didn't see those or didn't answer yes/OK/allow then delete the
phone and start over fully repairing it. Be sure to delete both the car from the phone screen AND the phone from the car screen.
Old 02-22-21, 03:21 PM
bvshearz
bvshearz's Avatar
Found the problem....I hope...seems to be doing fine ...for now....turned the car of/on several times to check.
I was able to find the screen in audio that asks.... which portable device do you wish to connect?
There are 2 choices of course...My Brides.. and my phone...My phone was already highlighted as the one to connect,but....
something that I didn't know existed was the two choices below that ...
Top says "Connect via the cars audio system"...or something like that.
Bottom says "Connect via Portable player selected"....So that's why...it wanted the portable player to connect every time instead of the cars system connecting to it automatically ....As soon as I highlighted the "Connect Via the Cars system" ...it started playing music without me needing to do anything else.
Old 02-22-21, 05:39 PM
PauloFR
PauloFR's Avatar
Do you have a 2010 or up? Audio streaming wasn't available before.
I have a Note8 and it connects flawlessly every time I get into the car.
Old 02-22-21, 08:47 PM
CowBoE
CowBoE's Avatar
We have iPhone 7 plus and iPhone 8, and they connect automatically every time.
But I leave the bluetooth turned off 99% of the time to conserve battery
and only turn it on when needed.
My 2006 GS300 only does bluetooth phone calls, and does not do audio streaming.
Old 02-23-21, 04:31 AM
bvshearz
bvshearz's Avatar
my car is a 2011 model
Old 02-23-21, 07:11 AM
MX73
MX73's Avatar
I would do a delete and pair again from the vehicle. If you reset your phone or if there was an update to the phone, the vehicle may have issues trying to connect to the phone.
Old 02-23-21, 08:42 AM
mcomer
mcomer's Avatar
If you ever see in the Bluetooth screen of your device the name "Car Audio System" instead of the
cars default "Multimedia System" (older Lexi) or "Lexus GS" (newer Lexi) you should completely
repair the device.
bighitphot
ES - 5th Gen (2007-2012)
04-24-18 03:15 PM
seanaine
05-20-17 03:58 AM
g26
04-03-12 07:15 PM
cmalley
10-16-06 08:31 PM
hashs99
07-10-06 10:03 AM
Quick Reply: cell phone via blue tooth
