daytime running lights????
Old 07-25-14, 12:25 PM
gs350trev
gs350trev's Avatar
Default daytime running lights????
so i just put some new daytime running lights in.... I wanted to know if its normal for them to only be on during the day and when i have my headlights on they go off????? I got them from ijdmtoy's.. I guess i thought they always were on when i had the stock ones in...
Old 07-25-14, 01:48 PM
jamodeo
jamodeo's Avatar
They go off when low beams are on and turn into your high beams when you flip your high beams on.
-Joe
Old 07-25-14, 02:16 PM
Mistahoo
Mistahoo's Avatar
They are daytime running lights, they are only running during the day at half power when your headlights are off. Same bulb is your high beam. If you replaced the bulb for LED, you no longer had high beam. There's another bulb (parking light) in the same housing
Old 07-25-14, 03:11 PM
gs350trev
gs350trev's Avatar
i used LED so now i don't have high beams right????? so is there a way to have them run both at the same time or no??? I have a 2007 3gs thanks
Old 07-25-14, 03:27 PM
Mistahoo
Mistahoo's Avatar
No. Your high beams and drl are the same bulb. For drl it runs the bulb at half power, high beam runs the bulb at full power.
Old 07-25-14, 07:03 PM
gs350trev
gs350trev's Avatar
Ok, thanks for the info
johnbmech
05-09-19 08:59 PM
JamesBond1
55
08-08-17 05:00 PM
KeleIS250
02-23-12 08:01 AM
mugenh22a4
IS F (2008-2014)
10-31-10 12:22 PM
Quick Reply: daytime running lights????
