Tire sizes for those on bags...
Old 07-01-14, 04:49 PM
avs20
avs20's Avatar
Default Tire sizes for those on bags...
I'm currently running 275 30 20 Sumitomo's in the rear on a 10.5" wheel. What sizes are you guys running without rubbing? I'm scared to switch brands because I know some tires are slightly wider than others with the same size, but I'd also like a tire that isn't as stretched.
I'm running 20x10.5 with a 45 offset in the rear with zero rubbing, and shaved fenders.
Thanks for any input you may have guys!
Old 07-01-14, 05:28 PM
SLOW4DR
SLOW4DR's Avatar
Tire is too big. If you don't want a stretch run a 285/25/20
Old 07-01-14, 06:01 PM
avs20
avs20's Avatar
The tire isn't too big...it doesn't rub at all. I'm afraid a 285/25 will be too wide. It's almost 1/2" wider...plus the sidewall height of the 285 scares me, but I'm definitely going to look into it...Thanks!
Old 07-01-14, 08:05 PM
Schmexus
Schmexus's Avatar
I run a 275/30 with +35 on a 20x10.5 and had to do what I consider minor trimming on the fender and bumper tab to tuck them. I also added a tiny bit of negative camber. The inside of the tire hits the bag slightly at full drop. I would imagine with +45 I'd be cutting into that bag pretty good.
Are you rubbing the rear bag at all?
Old 07-02-14, 12:04 AM
1SLOGS
1SLOGS's Avatar
I Have Vossen CV1 on my 3GS and the specs are 20x9 and 20x10.5 with 225/35/20 in the front and 245/35/20 in the rear and the offset on the wheels are +25 all the way round. no rubbing issues also i have my rear fenders rolled.
Old 07-02-14, 04:33 PM
Need4Speed
Former Sponsor
Need4Speed's Avatar
275/30/20 will be fine
I have done it before on stock height lowered on springs, coilovers and bags
if you want a stretch then a 245/35/20 for the rear
( my current setup is 20x10.5 custom offsets 235/35 & 245/35 )
Old 07-02-14, 05:18 PM
avs20
avs20's Avatar
Sorry if I wasn't very clear guys..I'm already on a 275/30/20 with a 10.5 rim. I have zero rubbing on the fender or bags. I was trying to run a tire that is less stretched than the 275, but it seems that I might be running the widest tire I can run. I might just stick with the same brand/size and not mess with something that already works
1herm4
RC F (2015-present)
04-13-18 06:58 PM
f0unta1n
01-15-16 07:44 PM
Abelo
SC- 1st Gen (1992-2000)
17
03-31-14 05:15 PM
kbh
08-19-09 09:20 PM
milky
VIP Style
24
02-05-09 01:51 PM
Quick Reply: Tire sizes for those on bags...
