Vais bluetooth audio stream
Old 09-22-14, 02:18 PM
  #31
pwrusr
pwrusr's Avatar
Originally Posted by jli
Hello pgn628, thanks for the info. Does the kit come with the extension usb cable or i have to buy it separately?
Have to buy it separatly. I just got a nice 10ft from Amazon routed it from the unit and into the center armest console.. A suggestion is you place your unit in the glovebox. There is a panel that pops out. Therefore if there was an upgrade in the future or if you ever need to access the box it is right there.
Old 09-23-14, 05:54 PM
  #32
verly6565
verly6565's Avatar
i wonder if it will show video
Old 09-24-14, 12:09 AM
  #33
rominl
exclusive matchup
rominl's Avatar
sl3b only sound
Old 09-24-14, 07:23 AM
  #34
pqn628
pqn628's Avatar
They have a product that will display video but its over 500 dollars. not worth it to me.
Old 09-24-14, 10:01 AM
  #35
SmokeyLex
SmokeyLex's Avatar
Do I just go to a sound shop to have it installed? I dont trust my electronics installation skills
Old 09-24-14, 10:03 AM
  #36
pwrusr
pwrusr's Avatar
it's very easy. Pretty much plug and play. The hardest part you will have is nudging the head unit console out. Just make sure you put the car in N and have a cloth over the shifter so you don't scratch anything. Follow all the DIY instructions here.
Old 09-24-14, 11:11 AM
  #37
pqn628
pqn628's Avatar
As mentioned above, its plug and play. Very easy to do as long as you follow the instructions on removing the head unit. Just make sure you dont do it on a cold day since clips tend to break easier on colder days than warm days.
Old 09-24-14, 05:08 PM
  #38
verly6565
verly6565's Avatar
pqn628 ,what model number are you referring to. do you have one installed on a v4 2006 gs,
if so im buying one asap
Old 09-24-14, 05:13 PM
  #39
rominl
exclusive matchup
rominl's Avatar
for 06 gs there is no unit from vaistech that can do video. it has gen4 nav
Old 09-25-14, 04:54 PM
  #40
verly6565
verly6565's Avatar
since theres nothing for the 2006 gs300 v4 ill do what i did for my jag x-type watch the video ,
all i need is the wiring diagrams ,if anyone has a link pleases post it
heres my multi media set up in my jaguar x-type ,sit back and watch
click on video below
Old 09-28-14, 02:07 PM
  #41
Lexus GS3
Trouble Maker
Lexus GS3's Avatar
I have the SLB4 unit for almost a year now. It work flawlessly with my previous iPhones 5 and 5s running iOS 7.
Now I upgraded to iPhone 6 on iOS 8.0.2. Unit works fine, but it's glitchy sometimes. I think is an iOS issue or SLB4 unit is not 100% compatible to iOS 8.
Gonna call vaistech and find out more.
Old 09-29-14, 07:28 PM
  #42
verly6565
verly6565's Avatar
does the slb4 show video or mirror your phone
Old 10-15-14, 01:21 PM
  #43
supags
supags's Avatar
Originally Posted by pqn628
Installed mine on Friday. It took about 45 minutes to install. If you get this, make sure you follow the instructions on page 6 to sync the device to your car...
I have both Samsung and Iphone and I think it works better with the Samsung. I mainly use Pandora for music. With the Samsung, I can open Pandora and start playing it right away. With the iPhone, I have to have at least 2 play list setup. This is how the device loads the iPhone. Every time I connect my iphone, i have to wait for it to sync up with the play list and then open Pandora
the sound quality is great. Its just as good as the toyota ipod interface hard wire. I like how there is a USB port to connect a USB extension cable. This allows me to charge both my devices. I ran the extension table into my center console and have a iPhone and Samsung cable in there.
If you dont have the plastic tool kit to remove the unit, don't waste your money. I just used two credit cards and the unit came out real easily.
Hello,
I just got my device today and I wanted to confirm that I have to sync the device with my car first? or do I just plug and play? I have a 2006 gs300 non NAVI so which emulation mode I should be choosing? CD CHANGER emulation mode installation?
thanks in advance
Old 10-15-14, 02:45 PM
  #44
mindcrime
mindcrime's Avatar
pictures of the unit in glove box? i never got around to install the SL3I, so if anyone is interested, pm me. brand new in box.
Old 10-16-14, 07:14 AM
  #45
supags
supags's Avatar
Do you have any pictures of the setup? I'm not sure how you got it installed in glovebox and the USB wire coming from center armrest ? did you drill hole?
Quick Reply: Vais bluetooth audio stream
