2006 Lexus GS 300 airbags
Ive replaced several airbags and never had to replace impact sensors, just the bags and reset the computer. Once you plug in the reformatted module, and if there is any SRS light, it will tell the mechanic if there is any damages
Ive used a guy off of ebay I think it was around $45-$60 he can reset modules.
Isn't possible to reset it by myself? How much does the resetting device cost?
Also I found this on the net can I try using this procedure to switch off the dash airbag light for my vehicle?
I've had my airbag module reset locally, but I would assume myairbags does the same thing. I replaced the rear airbags and side curtains myself. The rear bags were easy, the sides were a pita because you gotta deal with the headliner. I still have an extra side impact sensor if yours was hit.
I think my impact sensors are ok, as they don't have any phycial damage, I have been told once those sensors sence or had an accident, then, they have to be replaced with new ones or used ones which did not have an accident.
I live far away from the States, I live in the Middle East, so it would be difficult to send the airbag computer module overseas for resetting.
Contact the company and see if they can mail it to you, you never know.
I live in Oman, where about are you?
If the resetting device doen't cost a lot, I might by one for my self and for those who have such a trouble, how much does the resetting device might cost?
I am looking for the device which is reseting almost for all the vehicles, that would solve such problems in those vehicles which are having these problems.
If your airbag system is from a crash then a special reprogrammer tool is needed.
If you just have an airbag light and not from a crash then those are easily reset from a good mechanic with a scan airbag tool.
The problem I see if you did send your module out for repair is they may not have the program to rewrite your module for you. I'm assuming your Lexus is a Gulf-spec/Japan it maybe different
How to Reset / Repair clear crash data from Toyota Scion and Lexus airbag module * airbag Computer * - YouTube
I have imported my unit from the USA, so I think it could be done.
Most of our used vehicles at here have been imported from the USA as they are more cheaper, and it is easier to find used item for the imported unit comparing to Khaliji. Once you got free time, please visit Sharjah market your might be amazed!
cemiv8
09-12-18 05:07 PM
Babak
11-03-17 02:02 PM
mbonet
08-16-08 02:02 PM
