Avoiding the rub?
Old 01-19-14, 03:52 PM
darinmg
darinmg's Avatar
Default Avoiding the rub?
2007 GS430 with nf210s and rear camber arm, stock wheels.
Want to put spacers on my car and can't figure out what I can fit with out rubbing issues. If I follow the measurement process on the H&R website, it looks like I will just clear the fender, but I need to know if I'll clear the fender liner under compression. I've seen at least one thread that says 20mm front and rear will rub front and rear, but doesn't say the extent or when it rubs. If I do 10 in front and 15 rear will it rub? Do our wheels tilt in when going up? Is there a way to test this without wasting money on the spacers to see what works? Maybe a way to measure the space under full suspension compression?
Old 01-19-14, 08:13 PM
MyIS350G
MyIS350G's Avatar
15mm will not rub..
Im on Tanabe NF springs with oem 245 tires and 15mm spacers. still plenty of clearance
Old 01-22-14, 09:42 AM
ZaxF
ZaxF's Avatar
I've got 20mm adaptec spacers for sale that will work on all 4 corners with no rubbing. I used them on my 18" fan blade factory wheels. LMK if you're interested.
RSXiMUS
IS F (2008-2014)
01-29-15 09:16 AM
BrooksLC
09-23-14 10:56 AM
jsmacks
Suspension and Brakes
12-24-12 02:10 PM
cm09578
IS F (2008-2014)
07-23-09 08:30 AM
JDKane527
03-24-09 07:23 PM
Quick Reply: Avoiding the rub?
