Jerk/jolt/clunk when coming to a stop
Old 02-11-15, 09:28 PM
Gotcha350
Gotcha350's Avatar
Originally Posted by Tantrix
Sounds like the engine mounts, my old acura legend had the same problem till I changed out the mounts....it could be something else.
+1....i still have my Legend and experienced the same thing along with vibrations...it was the motor mounts...I would start with an inspection of those as well...
Gotcha350 is offline
Old 02-14-15, 07:33 PM
ta1972
ta1972's Avatar
My 06 gs430 currently developed the down shift clunk. Same issues. Don't think it has anything with the mounts. While I was coasting around 20 miles I put the gear in neutral and braked, There was no clunk. Only happens when I'm in gear to coming to a stop. It up shifts fine thru all the gears. The mileage on my gs is 145k miles. I Drained and filled the fluid about a few times. I didn't do a flush.
There are two clunks that happens. While I'm coming to a stop, a small noticeable clunk and followed by a slightly bigger clunk. What could it be? Some people are saying that it could be some solenoid or the ecu? Which ecu? Engine or trans?
ta1972 is offline
Old 02-16-15, 08:17 AM
AlvinGS300
AlvinGS300's Avatar
Excatly the same thing is happen my mine it has 140k and it's annoying everytime I come to a stop its jerking. Let me know if you find the problem.
AlvinGS300 is offline
Old 02-16-15, 08:27 AM
ta1972
ta1972's Avatar
I also noticed a 4th to 5th gear delay and slightly rough up shift. What the hell is going on?
I thought these engines and trans suppose to be "bullet proof" if u maintain them. Wtf!
Another thing is, does anybody know if there would be a stored codes without showing any " check engine" light? With these issues on my car, there no check engine lights that are on. Kinda wish a fault light would show so u could get it checked out to see which sensor or solenoid.
ta1972 is offline
Old 02-16-15, 01:13 PM
ta1972
ta1972's Avatar
My 2nd gen with a lot more mileage has no issues on the trans. I think these 3rd gen 6speed auto are weak links on them.
ta1972 is offline
Old 02-21-15, 10:59 AM
ta1972
ta1972's Avatar
Does anybody have some answers for these issues or clueless?
ta1972 is offline
Old 02-22-15, 08:29 PM
monkeyRX
monkeyRX's Avatar
got this same issue... anyone with a clear diagnosis and fix please share.
monkeyRX is offline
Old 02-22-15, 08:38 PM
sam12345
sam12345's Avatar
Entry #24 on this thread maybe?
https://www.clublexus.com/forums/gs-...w-speed-2.html
sam12345 is offline
Old 02-23-15, 08:45 PM
monkeyRX
monkeyRX's Avatar
That fix sound promising... would love to hear if anybody else has had success with replacing the shifter solenoid.
monkeyRX is offline
Old 03-13-15, 10:42 PM
ta1972
ta1972's Avatar
It's finally fixed!!! I'm super happy!!! It was the fricken ecu all this time!!! Lexus should make this a recall!!!
ta1972 is offline
Old 03-15-15, 09:19 PM
LsG86
LsG86's Avatar
How much did this cost you out of pocket?
LsG86 is offline
Old 03-15-15, 11:55 PM
ta1972
ta1972's Avatar
I did a lot of research and spent around $1500 in parts only. I did all the labor myself.
These were used parts and some new. This would of cost to the average person around a few grand and up.
ta1972 is offline
Old 03-18-15, 04:24 PM
AlvinGS300
AlvinGS300's Avatar
I replace my transmission because Lexus told me it was bad and still I have the same issue...so I'm happy that you replace the ecu and it works. Where did you get the ecu from, how much it's gonna cost and does it need to be reprogram?
Old 03-19-15, 09:57 AM
ta1972
ta1972's Avatar
If lexus told you to replace and still the same, then you should complain to them for misdiagnose first.
They have to take responsibility for that. If they can't help you, then you would need to find out your ecu part number. You would have to get the exact part number to marry it to the car.
Pm me if you need some advice.
ta1972 is offline
Old 04-21-15, 03:49 PM
Grissom357
Grissom357's Avatar
Hey do you have a direct email or number I really need advice love this car and I'm sitting at a dealership about to trade because Lexus told me I may need to replace my transmission... What's the ECU I need help please!!!!!
Grissom357 is offline
Quick Reply: Jerk/jolt/clunk when coming to a stop
