uas bag install question
Old 12-07-13, 06:44 PM
1SLOGS
1SLOGS's Avatar
Default uas bag install question
I'm trying to instal UAS bags and am running into an issue of where to connect the remote wire so the the compressor turns on only when the car is on and someone said connect it to the cig lighter pink wire but it kept blowing the fuse that was there.... And now I'm lost as to where to connect the remote wire.
Thankyou in advance
Old 12-07-13, 11:12 PM
swtjlsy
swtjlsy's Avatar
there is a blue wire in the driver side door acess panel that is the ign switch factory wire
Old 12-08-13, 02:52 AM
XxGoKoUxX
XxGoKoUxX's Avatar
Before he continues, there's no remote wire for compressors, unless he means the ECU LOL.
Remote wires shouldn't draw anymore than 1a of power really... It's just to tell the system, "Hey, wake up! I need you to work"
Sort of like a light switch really. You should know Mike, No accuair/Ridetech system draws power in the remote wire region lol....
Old 12-08-13, 02:00 PM
1SLOGS
1SLOGS's Avatar
Thank you for the Info i will look into it.
Old 12-08-13, 07:37 PM
XxGoKoUxX
XxGoKoUxX's Avatar
Make sure it's the correct wire 1SLOGS, it has to be crazy amperage draw to suck the juice out of your system until fuses pop.
Old 12-09-13, 03:56 PM
1SLOGS
1SLOGS's Avatar
Sure thing man i currently ran into another issue my Steering tilt stopped working and all i hear is clicks when i press the tilt button so now idk what to do and how to go about fixing that….
Old 12-11-13, 11:28 AM
XxGoKoUxX
XxGoKoUxX's Avatar
That's not what you did, the steering tilt gears are broken, hence why you hear the click and no moving. It's like the fold in mirrors..... It's a big YIKES, and you'll either have to have it disassembled and replaced or you'll have to shell out some money for the new system.
RAMAIR
11-26-22 11:18 AM
g3ner1k
ES - 5th Gen (2007-2012)
01-13-15 06:28 AM
Pnuge88
01-12-11 11:44 AM
DRFT103
Performance & Maintenance
09-07-09 09:03 AM
Conceptvip
SC- 1st Gen (1992-2000)
12-24-04 02:22 PM
Quick Reply: uas bag install question
