GS430 ABS , Brake Lamp on after replace brake pad by myself
Old 03-27-14, 01:53 AM
tunedis95
tunedis95's Avatar
Have to disconnect the battery when working on brakes, at least for the GS430. The car actually isolates the wheels you work on, pretty weird. Finally learned after driving to the dealership twice with only rear brakes. Ha ha. Once I'm done working on the brakes I pump the brakes several times them connect the battery. Never had an issue since.
Old 03-31-14, 01:27 PM
Skggyy
Skggyy's Avatar
Originally Posted by dcarrascoj
Hi...I was wondering if you happen to know what the problem was? I am having the same problem with 06 GS430. If you happen to know who you sent the car to, it to would be helpful.
Thanks,
Dino
They scan the same code that I got from Lexus Dealer. But Dynamics simply reset it for me. The code never comes back then. They using come laptop has Toyota Logo on it.
Old 02-28-18, 11:49 AM
SUPA
SUPA's Avatar
Originally Posted by Skggyy
2006 GS430 110K miles. Did Front brake pad change by myself. Now ABS , brake warning lamps come on.
Bring it to Lexus dealer. They found 3 code on it. C1203, C1336, C1345
After performed the Zero Point Calibration, the DTC C1345 remains.
I felt so bad. They want to charged me another $185 in order to find out the problem after i have paid $130. But i am our of pocket. So drive car back to home. Wish i could find some help here for my pocket. I don't think i did anything wrong while changing brake pad. Just remove the caliper and push the piston back .
Detail of the Code:
C1203 engine control system communication fault
C1336 zero point calibration Yaw rate sensor undone
C1345 Linear valve offset not learned.
i have the same car and the same problem. It could be skid control ir brake actuator.
Old 10-11-18, 09:08 PM
rlacayo
rlacayo's Avatar
I have the same problem you had. What shop did you bring your car in in Fountain Valley. I live nearby. Thanks.
VIPNiSS
06-21-19 02:45 PM
kdecluette
06-28-18 08:17 AM
Gutz13
06-28-11 04:33 PM
GS4K
Suspension and Brakes
06-14-10 06:18 PM
shoehead
Wheels, Tires & Brakes Forum
09-30-05 12:13 AM
Quick Reply: GS430 ABS , Brake Lamp on after replace brake pad by myself
