GSh misfire issues?!?
Old 12-03-13, 02:49 PM
  #31
BLKGS450H
BLKGS450H's Avatar
Hey gang, I just had a mis fire 1,5,6 check engine light. I had it reset to see if it comes back. If it does what do you think...its an 07 with 50k. I have read all your symptoms and am wondering if it has any relation to the valve spring recall job?
Old 12-04-13, 08:19 AM
  #32
Speedy0o
Speedy0o's Avatar
Has the misfire stopped now or is it permanent?
Mine came and went as the oil temp was warming up but slowly got worse where it did it all the time under load, hot or cold! Turned out to be 1 duff coil pack plus 1 of the rocker cover gaskets leaking into one of the spark plug tubes, causing the coil pack to arc out and not give the spark plug its correct feed, so they cleaned up the coil pack and moved it to a different cylinder to make sure it was working and that was it!
So could b a coil pack/spark plug even though its throwing up multiple misfire codes! Do you get "multiple random cylinder misfire" code aswell (or something similar)??
Old 12-09-13, 07:03 AM
  #33
BLKGS450H
BLKGS450H's Avatar
its been since last tuesday and still no check engine light.. Yea it did read multiple codes like p302,305,306 etc..
Old 09-18-23, 10:33 AM
  #34
lintdin
3rd Gear
lintdin's Avatar
Default What ever happened?
Originally Posted by Speedy0o
Just tell them you keeping the loaner and that they can keep the GS lol! Hmm I can imagine your none too happy, its spent more time in the garage than in your possession! I would not be impressed either! ECU issues perhaps? Is it misfiring/playing up or just EML on?
Hello,
I stumbled upon your post from years ago. What ever happened and did they ever figure it out? I am dealing with this misfire 135 and already spent $2,500 changing out tons of stuff.
Old 09-19-23, 09:27 PM
  #35
ibidu1
ibidu1's Avatar
Originally Posted by lintdin
Hello,
Why are you changing a bunch of stuff and complicating things? What were the parts that you replaced? Did you use oem parts?
Old 09-20-23, 12:42 AM
  #36
lintdin
3rd Gear
lintdin's Avatar
Yes used oem parts. Changed out these:
air fuel sensor
plugs
fuel filer
fuel pump
fuel relay
all o2 sensors
gasket
coils
maf sensor
bunch of hoses
and ran injector cleaners
one shop said maybe change the injectors but at this point I have already spent $2,500 for all new parts and from what I read someone put in new injectors and still had the same problem.
has anyone solved their problem? I am still getting misfire 135
Old 09-20-23, 08:46 AM
  #37
ibidu1
ibidu1's Avatar
air fuel sensor
plugs
fuel filer
fuel pump
fuel relay
all o2 sensors
gasket
coils
maf sensor
bunch of hoses
I had a misfire from 1,3, 5 but it was because I replaced the spark plugs and one of the rubber o-rings seals in the connector came undone and when I washed the engine, water got trapped inside. All it took was cleaning out the terminals on the plugs.
But still this doesnt mean you have the same issue. Did you take it to the dealership and pay for 1 hours worth of diagnostics? $2500 thats a lot of money, your dealing with a slime ball mechanic whos not experienced in diagnostics. 1-2 hours is all it takes to figure out a misfire. You have a mechanic thats guessing and wasting your money.
JeffTexas7
04-26-22 11:24 AM
JimboGo
04-26-18 06:12 AM
Venom647
09-14-13 06:57 PM
BoostedE21
03-10-10 09:20 PM
Eric00GS3
09-14-07 08:17 AM
Quick Reply: GSh misfire issues?!?
