You can remove the cover by first taking of the shifter trim (the thing with the cup holders) then removing the panel with the buttons for your heated seats. After you do that you can stick you hand underneath and pop the cover inside your arm rest off. But, there's really nothing down there. There's like some airbag ecu or something. Not much room for anything. I drilled a hole in it and used it to run a usb charger wire thru.
