Fog lights safety question.
I notice my low beam plastic is also melting because it's cloudy but its been like that since I got the car 2 months ago. I am thinking of changing the plastic soon after i get new tires and rims.
I also got the HiDs installed on my car and did a test with my friend on the same road, he said it doesn't shine in other peoples eyes so I'm happy.
BTW could someone give me a link to where I can but the plastic or glass for my car?
It has factory HiDs so idk if that changes what glass or plastic is used.
$160-200 and I should be back on the road again!
It's all plastic, a tip though. If you can, take a bottle of water, and spray the headlight lenses, if it doesn't show the fogginess anymore, then it's the outer part of your headlights. That's 100% reparaible, a good sanding and detail on it and you should be good to go again .
Post your pics in a separate thread and I'd be glad to evaluate for you too if you'd like!
LOL, I've been told the same thing as you said about HIDs Simmsled. The whiter it is, doesn't mean it's brighter that is. I just don't bother arguing on the forums lol.
TY for the bulb suggestion! I'll definitely check this out!
EDIT: Out of this selection, which one would you recommend for the members? That along with the 9005's too! I'm sure people would be grateful for the suggestion.
http://www.rallylights.com/all/light....html?cat=1898
BAM. Read that. Those are where its at.
I had the headlights sanded and detailed. It helped a bit but the fog seems to be inside the headlight and you only notice it when the headlights are on though. BTW I checked how much it is for the headlight housing and its 200+ each side... I saw this on Lexus of Sewell parts. IDK if I am looking at the wrong thing.
