Puddle / Side View Mirror Light LED Replacement Instructions
Old 09-07-13, 01:48 PM
Majek
Majek's Avatar
Default Puddle / Side View Mirror Light LED Replacement Tutorial
Hey guys, I just installed LEDs into my puddle / side view mirror lights. I hope this to be a solution to all those who question if it's worth the effort to change the bulbs. Just follow my tutorial and you'll have no problems! It shouldn't take you more than 15 minutes total for both sides and you'll get a much brighter & whiter light output.
No time-consuming mirror removal or potentially damaging pressure application needed. These instructions also work for the LS430, since I have changed LEDs in that vehicle the same way.
You'll need:
1) Long Phillips screwdriver
2) Panel removal tool or taped flat screwdriver
3) Pair of brightest possible 'forward' or '360deg' 194 LED bulbs (not 'flank')
Instructions (from driver's side perspective):
1) Roll down your driver's window all the way. Turn your side view mirror all the way up with the power switch. You will notice there are two screws on the left and right bottom, underneath the mirror. To access the left screw, turn the mirror all the way to the right + up. To access the right screw, turn the mirror all the way to the left + up. Use your long Phillips screwdriver. You should have ample room without scratching any paint, but be careful anyways. If the screw is a little stiff, just hold the plastic mirror assembly with your other hand at the back while applying pressure with the screwdriver. DO NOT REMOVE the screws, just loosen them somewhat and leave them in their place.
2) With your hands, gently and slightly pull apart the front and back side of the outside plastic mirror assembly along the seam from the bottom to create some room for the light to come out. Use your panel removal tool or a taped flat screwdriver (to prevent scratches) and apply to the ROUNDED side of the puddle light (the part closest to the front of the vehicle). There are two plastic tabs there under the light. Just pry it out and then pry out the flat side of the light after. It will come out EASILY since you loosened the screws in step 1. If not, loosen the screws some more and try again.
3) Remove old bulb by turning counter-clockwise from the socket and install LED. Since the bulb goes in an angle, use a 360deg bulb for brightest output (a powerful forward bulb would also work well).
4) Check to make sure the LED turns on.
5) Re-apply the light back to the side view mirror by inserting the rounded side first and then the flat side. Tighten screws.
6) Do the passenger side. Done!!
* First photo is of the original stock bulbs. Notice they are blue-coated to give us that white-ish light. However, because of this coating, the bulbs are very dim.
* Second photo is of 5000K LED installed.
Attached Thumbnails Puddle / Side View Mirror Light LED Replacement Instructions-wp_20130907_001.jpg   Puddle / Side View Mirror Light LED Replacement Instructions-wp_20130906_004.jpg
Old 09-07-13, 02:51 PM
gvu20
gvu20's Avatar
Thanks for the tutorial, I will be buying the bulbs and attempt this mod.
Old 09-07-13, 03:55 PM
msequence
msequence's Avatar
Any way to make a quick Iphone video on what to remove and that part about outside mirror to make room for the light to come out?
Old 09-07-13, 04:08 PM
Majek
Majek's Avatar
Sorry, I put it all together now and don't have room in the garage to do it again. If you look at your sideview mirror casing from the outside (the foldable painted plastic holding the mirror), you will see there is a seam. When you loosen the bottom scews, you create a gap to allow easy removal of the puddle light.
If you follow it directly as I wrote, it's very simple, fast and a safe installation.
Old 09-07-13, 06:35 PM
XxGoKoUxX
XxGoKoUxX's Avatar
ty, will look forward to trying this and i'll update YOUR thread with pictures if I get the chance.
Old 09-07-13, 06:39 PM
SLOW4DR
SLOW4DR's Avatar
And here I thought the OEM puddle lights were LED's lol. Looks like i'll be upgrading them whenever I get the led mirrior covers from nigel...
Old 09-07-13, 08:08 PM
XxGoKoUxX
XxGoKoUxX's Avatar
OMG, I didn't want to feel stupid and say the exact same thing as you lol...... I guess SOME of the lights in our cars are still non-LEDs, (just like the fold down mirrors on our driver and pass sides).
Old 09-20-13, 02:20 PM
SLOW4DR
SLOW4DR's Avatar
For anyone that is curious, It's fairly simple.
push the top of the mirror in, stick your hands under the bottom and pull. After the bottom pops out, you just slide downward to get it out of the grove on top.
Then you get here. Remove the 4 phillips screws
pull the front part off and then push the puddle light housing off. I just pushed from the backside(from front of car pushed to rear as seen in next pic)
and before and after
Don't mind the reflections of myself brahs I'll post night shots of the lights after the gym later.
I used these ijdmtoy LED's
http://store.ijdmtoy.com/8-SMD-Wide-..._t10_sku18.htm
Old 09-21-13, 09:04 AM
XxGoKoUxX
XxGoKoUxX's Avatar
awesome SLOW4DR! I'll probably order mine's sometime next week!
EDIT: Which way does the bulb point? Is it straight down? or sideways?
Old 09-22-13, 12:41 PM
Majek
Majek's Avatar
If you don't want to pull out the mirror, follow the instructions I posted.
The bulb points downward in almost a 45 degree angle.
Old 09-22-13, 01:43 PM
XxGoKoUxX
XxGoKoUxX's Avatar
TY Majek, I thought both of your ways was the same.... I'll figure out which route I wanna go in due time . School currently pwns me so I'm just chillin for now till I have free time to order stuff lol.
Old 09-22-13, 09:06 PM
Majek
Majek's Avatar
Your welcome. Nope, each way is different. My method does not require removal of the mirror - it's the safest route. Good luck when you get the chance. Post pics if you can!
Old 09-23-13, 05:29 AM
msequence
msequence's Avatar
My question is, with the pull out mirror glass method, how do you put all the stuff back in?
Old 09-23-13, 06:28 AM
SLOW4DR
SLOW4DR's Avatar
Push it back on. It's clipped on the bottom of the mirror and then slides down to remove. To put back on, put the teeth in the holes, slide up, and push on the bottom to snap the clips back in. I'd recommend putting a towel or shirt over the mirror so you don't ruin the defrost and what have you in our mirrors.
Old 03-26-15, 07:29 PM
Rexor20
Rexor20's Avatar
bumping an old thread but I just wanted to add my experience. I found the "remove the mirror" and the "credit card prying" technique to be worthless. If I pulled on the bottom of the mirror any harder something would have broken, there was no give at all. For the credit card technique I'm not sure where you get credit cards that have harder plastic than whats found in the puddle light. My credit cards just bent when I tried to pry with them.
It took about 10 minutes once I tried this and loosened the lower screws.
Quick Reply: Puddle / Side View Mirror Light LED Replacement Instructions
