New Headlight Assembly
Old 09-02-13, 09:08 AM
mrwilliams
mrwilliams's Avatar
Default New Headlight Assembly
I have a 2006 GS and my headlights are yellowish in color. I've tried the headlight restoration and cleaners. But everytime I see a newer Lexus with those clean and crystal clear headlights I want a new pair. Does anyone know where I can get a NEW pair of headlight assembly's?
Old 09-02-13, 04:07 PM
IrvGotti
IrvGotti's Avatar
kbcarstuff.com they have a CL discount for new D4S bulbs
Old 09-02-13, 04:18 PM
SLOW4DR
SLOW4DR's Avatar
sewell lexus or your local lexus dealership.
Old 09-02-13, 10:45 PM
XxGoKoUxX
XxGoKoUxX's Avatar
I feel ya, I haven't tried the restoration process on mine's though, I want to remove the lenses first. I believe the dirty, yellowness is inside AND outside.
You can try the two sources above, or source out one on ebay. Sometimes they come out in REALLY good condition.
I don't think he means his headlight bulbs.... I think he means his headlight lenses in general.
Old 09-03-13, 01:57 AM
IXI187IXI
IXI187IXI's Avatar
car-part.com for possible cheap lights
Old 09-03-13, 07:04 AM
ibidu1
ibidu1's Avatar
Stay away from headlight restoration, all they do is Sand off the clearcoat that you had on your original headlight. Leaving your headlights exposed.
Take the headlight to a body shop and see if they can sand down the light and apply a clearcoat. They will look new again and last a lot longer
Old 09-03-13, 08:48 AM
mrwilliams
mrwilliams's Avatar
WOW!! I never heard of that before. But for a good price. I'll try it.
Old 09-03-13, 09:09 AM
XxGoKoUxX
XxGoKoUxX's Avatar
You didn't know that is the purpose of headlight restorations? You can also use rubbing compound to scrub it away..... You don't NEED to take it to a body shop, I did it with a spray can of clear coat (3x), sanded it smooth again, polished and sealed, and it lasted for quite a few years on my friend's prelude.
Old 09-03-13, 09:11 AM
ibidu1
ibidu1's Avatar
You can diy, but with apply the clear is a bit tricky to lay down properly. You'll need a two part clear, many auto parts stores sell these in a spray can for like 20-$30 bucks depends on material product used.
Heres a video showing how to do it
Old 09-04-13, 06:32 PM
pureplayer
pureplayer's Avatar
For some reason thou mines look faded from the inside.
Old 09-04-13, 08:06 PM
ibidu1
ibidu1's Avatar
As long as its 2k automotive clear coat it doesnt matter where you shoot it out of. Lots of paint supply shops will put a 2k clear in a compressed can for you for pretty cheap. You'll want a decent brand clear so that you get UV protection and the less yellowing.
I would say theres no need to wet sand and polish after if the clear has been laid down properly.
Old 09-04-13, 08:10 PM
ibidu1
ibidu1's Avatar
It may look like its is in the inside but you may just have deep pitting. I would tape off headlights, sand with 420, then 600 youll want to knock out all the old flaked clear coat.
Then spray on clear coat, or have a shop shoot the clear for you. Most shops will do it for dirt cheap as they can sneak them in when they finish clearing up from another job.
D3V3LOP3R
01-31-15 08:35 PM
Mancebof
03-09-12 08:35 PM
ILOVEGIRLS
Lighting
42
05-26-06 12:58 PM
DroppedLex
Lighting
12-27-02 02:36 AM
laser_doc
01-31-02 10:17 PM
Quick Reply: New Headlight Assembly
