Help!! Drl stopped working
WHATS UP CL, THIS MY 1ST POST AND IM HAVING SOME ISSUES WITH MY DRL ON MY 08 GS350 AWD. I RECENTLY GOT LED DRL's FROM iJDMTOY WENT TO INSTALL & LIGHTS DID NOT WORK. CALLED iJDMTOY & EXPLAINED MY SITUATION & THE REP HAD ME CHECK THE FUSES. SEEMS I BLEW OUT SOME FUSES BUT I REPLACED THE FUSES, I WENT BACK TO STOCK & STILL HAVE THE SAME ISSUE, LIGHTS WONT COME ON. STOCK OR LEDS. I TESTED THE STOCK HARNESS & IT WAS LIVE PRIOR TO THE FUSE CHANGE BUT SINCE HAS GONE DEAD. IF SOME1 CAN PLZ HELP ME FIGURE OUT WHAT TO DO I WOULD GREATLY APPRECIATE IT.
ALSO IF SOME CAN POINT ME IN THE RIGHT DIRECTION TO EXACTLY WHERE THE DRL FUSE IS TO DOUBLE CHECK IF THE FUSE I AM REPLACING IS CORRECT. THANX IN ADVANCE
Is your caps locks broken?
On another note, check the fuse box in the engine bay and see if that says "Hi-beam" or "DRL."
Also check in the passenger side under the glovebox and see if the fusebox has the same as above...
You also have a fusebox in the trunk on the driver side.
Wish I had my car but it's still in the dealership.
Found the problem fellas thanx for your help. It was a series of fuses blown. The DRL looking good. I highly recommend the LED lights w/ decoder from iJDMtoy. will b posting pix soon
wiring harness? that doesn't sound right. You could ALWAYS DIY the situation, if you know which section is burned up, you can always cut about 3-6in from each side and put a same gauged wire inbetween, solder if you have decent soldering skills or butt connector each end with:
Make sure to have shrink wrap available, shrink wrap everything and make sure no moisture. That's a DIY fix for maybe $10 at most? That includes excessive wire for you to use for the future.
I've never heard of the wiring harness burn out with O.E. specific bulbs. I use to run my Garax bulbs on everytime I took a drive and I never managed to burn out my wiring harness.
