Brakes again!
Brakes again!
So after replacing all four of my brake pads, rear brake caliper and rotor...The squeaking of the brakes still is there, whenever coming to a stop the brakes make the squeaking noise. Their has to be a solution to this problem, I know many of you guys in the past have mentioned this. But has their ever been a solution to fix them. Any input would be much appreciated. Thanks
I had the same problem when I first bought my car. I actually had to take my car back to the dealership 4 times to get a brake job done under TSB. By the fourth time, they told me the most recent update to the brake squeak TSB will fix the squeak for good. Sure enough it did. Been about 10k miles now with no squeak in sight. My recommendation? Take it to the dealership under TSB if you are able to.
