GS350 Common Problems Thread
Old 05-21-13, 09:36 AM
98GS430
98GS430's Avatar
Default GS350 Common Problems Thread
I've noticed several threads discussing issues with the 3GS but none describing common problems most seem to be experiencing. I figured I'd share to see if anyone else is experiencing the same.
So far my 2007 GS has had the following issues:
Valve spring recall
Water pump replaced at 60k miles
Cam gears replaced at 62k miles
Front wheel bearings replaced at 64k miles
Moonroof/Door rattles
Passenger side headlight going out intermittently. (Assuming it needs a new bulb)
I just clicked 64k miles and wondering what else is on the horizon I should expect?
Old 05-21-13, 10:22 AM
bigblack06
bigblack06's Avatar
Valve spring recall
Moonroof/Door/Dash rattles
Fixed one!!
Old 05-21-13, 10:26 AM
benztolex
benztolex's Avatar
How's your ML sub holding up? You may want to add that as well.
Old 05-23-13, 06:28 AM
98GS430
98GS430's Avatar
No issues with the ML sub yet. Keeping my fingers crossed I wont have the dreaded vibrations.
Old 05-23-13, 09:21 AM
alchemist
alchemist's Avatar
I've had:
Valve spring recall
Cam gears replaced at 78k miles
Dash/Door rattles
sherwoodgs
11-23-22 01:31 PM
cossie1600
08-09-18 06:22 AM
mrbulk
09-27-16 09:02 AM
ur1man
07-20-13 06:29 PM
Ziggy716
02-26-13 06:25 PM
Quick Reply: GS350 Common Problems Thread
