Hey picked up a set of vsxx from a member here isam250 great dude by the way!!, here are some updated pictures of the ride. With the lip it sits pretty low so I might just get rid of it. Cant make it up a driveway without being careful. No camber/toe kit.
The car is pretty low sitting on tanabe coils with 30mm front RCA kit.
looks great. dibs on the lip. what are your suspension mods? and is that the stock specs for alignment?
Yes those are stock specs for the alignment. I didn't have any custom specs for them to use. I didn't need anything special just wanted to dial it all in.
are you in Socal-OC? I'm going to install 30mm RCA block when I upgrade my brakes, doe's the rear need alignmend-07 GS350 RWD?
use to live in OC when I went to UCI, but I am in Ventura County. just remember you need 19" wheels to run RCA kit. If you do not do anything to the rear I don't see why you need a rear alignment. You probably don't even need a front alignment. I installed coilovers on my car and rode around for over a year and alignment was not off by much. However it is always advisable that you get an entire 4 wheel alignment.
do you recommend I wait to install the rca kit until I switch to the 19 inch wheels. current is 18 inch stock. i'll have the alignment checked regardless since i tend to slightly drift to the right. tires seems to be evenly worn though.
it wont even fit on 18 inch stock wheels. that's why you need 19+
