Need rearview mirror wiring help fast!
Old 04-17-13, 01:15 PM
costanza
costanza's Avatar
Default Need rearview mirror wiring help fast!
Can someone please tell me which of the red, yellow, blue, green and brown wires on the dimming mirror are constant-12 volt, ignition-12 volt and ground? I'm installing a new Gentex mirror with only those three wires. Thanks!!!!
Old 04-17-13, 01:24 PM
costanza
costanza's Avatar
It looks like red is constant. Brown is ignition. How do I fund ground? My guess is it's blue
Old 04-17-13, 02:09 PM
neurocity
Neu`roc´i`ty
neurocity's Avatar
Multimeters... They are handy for these situations.
RXGS (12-03-17)
Old 04-17-13, 03:20 PM
costanza
costanza's Avatar
I have a Multi meter. I did use it to figure out the constant and ignition 12 V wires. I was unsure about ground and what the other two wires were for. I used the Continuity setting to determine the ground wire. I held one wire on the cars body and touched each of the five wires and got continuity only on the blue. So, I no longer need the help, but maybe this post will save someone else a few minutes if they decide to swap mirrors.
Old 04-17-13, 03:31 PM
EyeKutr
EyeKutr's Avatar
I will try to wire up a radar detector soon so this will come in handy, I would use the blue and brown I guess
Old 04-17-13, 03:33 PM
KJSmitty
KJSmitty's Avatar
Originally Posted by costanza
I have a Multi meter. I did use it to figure out the constant and ignition 12 V wires. I was unsure about ground and what the other two wires were for. I used the Continuity setting to determine the ground wire. I held one and on the cars body and touched each of the five wires and got continuity only on the blue.
That may have been good enough yet it still could be a power wire that circuits to ground.
Take one lead (+) of your multimeter and connect it to your known 12 volt wire - I would use the brown wire that's hot with ignition on. Then check the blue wire again with the other lead (-): with ignition on, off, on with lights on etc. Make sure it remains a ground with the car on and lights on etc. You could also check your continuity like you did before yet do it with car on and again with lights on.
I don't claim to know what wires are what on the Lexus RV mirror yet have done several mods powered off rear view mirrors with strange and or different results on wiring - especially when looking for a true ground.
Just my experience talking etc..
Cheers
Old 04-17-13, 03:41 PM
costanza
costanza's Avatar
The red and brown wires were the only ones that showed 12 V at any time.
Old 04-17-13, 03:46 PM
costanza
costanza's Avatar
To access the wires easily, just pull the panel directly behind the mirror, straight down. The Molex style plug is white and you only see it if you put your head close to the center console display and look back underneath the sunglass holder
Old 04-17-13, 08:31 PM
morganc
morganc's Avatar
Hope this helps!
File Type: pdf
Old 04-18-13, 10:01 AM
costanza
costanza's Avatar
I had that diagram. Couldn't make heads nor tails of it, LOL
LewisLou
06-29-23 11:57 AM
Dangnm
ES - 6th Gen (2013-2018)
10-18-18 07:28 PM
socaligs
01-09-17 09:02 PM
dannyk8232
IS F (2008-2014)
12-24-14 11:23 AM
Quick Reply: Need rearview mirror wiring help fast!
