Am I the first with this exhaust leak?
Old 04-03-13, 06:28 PM
dubzino
dubzino's Avatar
Default Am I the first with this exhaust leak?
I went to get my brakes checked by a local shop today. And I showed him that loose ring underneath that you can see has rusted off of the pipe cause it makes an annoying tingling sound. Then he explained to me that these cars are prone to getting exhaust leaks from the moisture getting in between the pipe and the shield. He raised up the shield slightly and showed me where the exhaust was leaking.You can see a small hole in the picture from the clip but there is a bigger one under the shield starting out. He was a master at the local lexus dealership for over 15 years so he knows these cars in and out. Has anyone had this issue? Did lexus fix it under emission warranty? He told me to go in there and complain. Cause a buddy of his that still works there said they are now making a tsib to change the whole pipe. Before I take it in I just wanted to see if anyone else has had this done or fixed under warranty. As he says they should change it out under warranty.
Attached Thumbnails Am I the first with this exhaust leak?-20130403_210116.jpg
Old 04-03-13, 06:58 PM
GS350Lexus
GS350Lexus's Avatar
How much miles are on the car? I also had one of the ring come loose and rattle like crazy, we removed it and installed a brand new one. Does the exhaust leak make noise inside the cabin at all?
Old 04-03-13, 08:08 PM
ibidu1
ibidu1's Avatar
I had the same exact thing happen to me. Took it to my muffler guy and $25 bucks later as good as new.
He ended up taking off the heat shield he explained to me that the shield was helping the exhaust rust quicker and that the exhaust pipe metal is really thin. He removed the clamps and the shield and just welded it solid.
Old 04-04-13, 03:08 AM
dubzino
dubzino's Avatar
Car has 99000km on it. If your parked and you open the door and press the gas you can notice it.
Old 04-04-13, 09:43 AM
gs4thirty
gs4thirty's Avatar
same thing here in my 06 gs430 with around 45k miles. Easy muffler shop fix
Old 04-06-13, 01:22 PM
dubzino
dubzino's Avatar
So for the record this is not covered as part of the emissions warranty?
Old 04-08-13, 06:36 AM
ILLYWILL
ILLYWILL's Avatar
how many miles you have about if your under 80,000 I believe its under warranty I just got mines replaced under warranty I have 66,000 on my 07 gs 350
Posted from ClubLexus.com App for Android
Old 12-31-13, 10:02 AM
lexus06300
lexus06300's Avatar
Default exhaust
i have a 2006 gs 300 with 73k miles on it. did the warranty cover it for you guys?
Old 12-31-13, 11:38 AM
BinaryJay
BinaryJay's Avatar
Two of mine rusted to pieces, I replaced them... I suspect there is something going on under there but it hasn't caused any kind of issue so... haven't done anything about it.
Lexus once told me there was a leak causing an O2 sensor code, but I fixed it and had nothing to do with the O2 sensor itself or leak since I did nothing to the exhaust. They did not offer me any kind of warranty fix for it, just said take it to a muffler shop (which told me they heard no leak) or they could replace the whole exhaust for like 2 grand... so yeah either it's not covered under emissions warranty or they just didn't feel like helping.
Fysisist
RC F (2015-present)
76
08-01-19 11:54 AM
lexus06300
01-01-14 11:24 AM
Itsablurr
07-02-13 12:57 PM
snaggle
Performance
18
08-28-11 10:13 PM
Todd
RX - 1st Gen (1999-2003)
12-30-03 08:53 AM
Quick Reply: Am I the first with this exhaust leak?
