which tires for 20 inch wheel?
Old 04-01-13, 02:28 PM
loccsta187
loccsta187's Avatar
Default which tires for 20 inch wheel?
i have 20x9 for front and 20x10.5 for rear
currently im running 245/35/20 and 275/30/20
should i switch to 245/30/20 instead for the fronts? I read that 245/35 is not the right size for the fronts
Old 04-01-13, 08:52 PM
onephatguy
onephatguy's Avatar
I'm thinking of going to 245/30/20 front and 285/25/20 rear. That is supposed to be as close to original rolling diameter.
Old 04-01-13, 08:57 PM
greyhndfan
greyhndfan's Avatar
I'm running:
Front 20X8.5 R-Disk et 38mm
Rear 20X10.0 O-Disk et 45mm
Tires: Hankooks Evo110 V12 245/35/20 and 275/30/20
Slightly overspec, so I do scrape even after pushing in my wheel lining. I'm also dropped an inch on front and back suspensions.
I opted to get that extra wheel height to offer my rims some protection against pot holes.
Old 04-04-13, 06:56 AM
loccsta187
loccsta187's Avatar
Originally Posted by greyhndfan
I'm running:
I just ordered those exact same tires... How are you liking the v12s?
I had Ventus ST's on my 08 harley f150 and they were awesome
Old 04-04-13, 07:45 AM
benztolex
benztolex's Avatar
onephatguy tire specs are ideal. If you run the same size as greyhndfan you will experience the same. I've read great things about the V12's.
Old 04-05-13, 12:54 AM
designo
designo's Avatar
You have two choices
if you rub
go for 245/30/20 and 285/25/20
Old 04-06-13, 07:39 AM
onephatguy
onephatguy's Avatar
if you rub
I do rub, so that's why the next set will be 245/30/20 and 285/25/20. I'm currently running 245/35/20 and 275/30/20 Falken's. Wish I would of went with my gut, but another Lexus owner convinced me to run the first set.
Old 04-06-13, 07:56 AM
LexG
LexG's Avatar
Here is Discount Tire's wheel calculator. Keep in mind your wheel width when comparing.
http://m.discounttire.com/dtcs/infoTireMath.dos
Old 04-06-13, 04:02 PM
anhvn05
anhvn05's Avatar
I'd go with 245/30/20 and 285.25/20 mine rubbed with 245/35/20 and 275/30/20. Ride will be a little bumpier but at lease it's less likely to rub.
RONSKI23
01-14-14 12:48 PM
350nub
VIP Style
19
06-22-08 06:26 PM
J-RO
05-25-07 09:15 AM
02Ku
Wheels, Tires & Brakes Forum
04-06-06 08:42 AM
ted920
01-29-04 12:43 PM
Quick Reply: which tires for 20 inch wheel?
