5mm spacer......
Old 03-06-13, 09:41 PM
c-low
c-low's Avatar
Default 5mm spacer......
Ive seen alot of posts about wobbling, shaking and wheel vibration using a 5mm spacer. I will be running 20x9.5/10.5 +23+24. If i wanted to add a 5mm spacer what would all need to be done other than shaving? Or is there really a huge downside to adding this size spacer?....
Old 03-08-13, 10:06 AM
redbaron
redbaron's Avatar
I had 10mm spacer on a 2 gen GS400 and it was fine with no wobbles. I mainly used them to bring the wheel out further to bring it flush with the fender and the spacer helped to achieve the look I was after.
I would recommend using a quality spacer. I believe I used H&R.
Old 03-09-13, 09:47 AM
c-low
c-low's Avatar
Ya i saw some posts about how people jus use 10mm cause they were complaining about wobbling or wheel shaking with 5mm
Thomasbjoe
Suspension and Brakes
08-03-19 07:28 AM
DeezNuts
SC- 1st Gen (1992-2000)
05-27-11 04:47 PM
jtgs400
Wheels, Tires & Brakes Forum
09-18-07 10:55 AM
dlexmon
GS - 1st Gen (1993-1997)
04-21-05 11:51 AM
Quick Reply: 5mm spacer......
