2006 GS300 Ballast question
Old 12-02-12, 08:30 AM
Spondon83
Spondon83's Avatar
Question 2006 GS300 Ballast question
I came home from business travel to find that the Stealership wants to charge big money to replace the ballast on the right front headlight...bulbs are new so that is not the issue this time.
this has to be something I can do myself...does anyone know what the replacement part number is and where I can find a good deal on one?
Old 12-02-12, 10:23 AM
SNiiP3R
SNiiP3R's Avatar
Search on ebay for D4S ballast. It should be around $50 - $70
Old 12-02-12, 10:50 AM
worker
worker's Avatar
i think most of that charge is the labor.
Old 12-02-12, 12:56 PM
PHML
Master Thread Closer!!
PHML's Avatar
I did an OEM ballast swap on my buddy's IS300 years ago. Its very doable as a DIY, but was a bit more difficult vs. an aftermarket ballast install. I say this cuz Lexus likes to attach the ballast under the headlight unit...and run the wires to hide them as much as possible...so it took some extra time.
Good luck though...just make sure you get the exact part number to swap out.
Pete
Old 12-30-12, 04:46 PM
Spondon83
Spondon83's Avatar
so does anyone know what the ballast part number is?
Old 12-30-12, 06:18 PM
ibidu1
ibidu1's Avatar
Im sure there are tons of used ballasts on ebay
Did you test the power going to the ballast to make sure thats the issue?
Old 12-30-12, 06:21 PM
ibidu1
ibidu1's Avatar
Used
http://www.ebay.com/itm/HEADLIGHT-BA...2d3a6c&vxp=mtr
New
http://www.ebay.com/itm/Toyota-Lexus...7497ff&vxp=mtr
Old 01-04-13, 01:13 PM
Spondon83
Spondon83's Avatar
Neither of these are capatible with my 06 GS300
Old 01-08-13, 01:12 PM
Spondon83
Spondon83's Avatar
Default Swapped out the Ballast...Still doesn't work!
Swapping out the ballast is a fairly painful job..once I installed the replacement ballast, It still did not help my light issue.
The light still comes on initially, but then turns off....I have installed a new light and ballast... Any Ideas?
Old 01-08-13, 01:22 PM
IXI187IXI
IXI187IXI's Avatar
swap the bulbs to the opposite side and see if the problem stays at the same headlight or moves to the other
Old 01-08-13, 02:18 PM
ibidu1
ibidu1's Avatar
So every single time you start the car the bulb turn on? Your best bet is to grab a volt meter to the headlight plug for the ballast. Start the car and see if the voltage drops when the headlights turn off. You may have some other issue going.
What do the headlights do when you use a different setting on the control stalk? Like the auto headlight setting?
Old 01-14-13, 11:35 AM
Spondon83
Spondon83's Avatar
I've tried the Auto setting and Manual settings with the same results. Looks like the BCM may be bad.
Old 01-14-13, 12:03 PM
IXI187IXI
IXI187IXI's Avatar
did you try swapping the bulbs to the other side? what type of bulbs did you buy?
Old 01-21-13, 04:38 PM
Spondon83
Spondon83's Avatar
Yes I did swap the bulbs with the same result....I bought the bulbs from the Stealership so they should be the right ones.
tokio417
09-13-18 02:54 PM
cremaster
IS F (2008-2014)
12-05-17 12:44 PM
c-low
02-25-13 07:28 PM
Jspektunin
06-01-12 11:32 AM
milellie11
07-06-11 07:29 AM
Quick Reply: 2006 GS300 Ballast question
