Audio problem
Old 10-05-12, 11:28 AM
3GS350RWD
3GS350RWD's Avatar
Default Audio problem
Hi guys, I need some help here. I started my car and drove it as usual. After a few miles the audio kept turning off and on by itself. I tried to turn off the engine and restarted the it but still doing the same thing. Any idea what I should do to fix it? It has the vaistech installed already when I got it from the previous owner.
Old 10-05-12, 12:03 PM
neurocity
Neu`roc´i`ty
neurocity's Avatar
I would venture to say that the owner. Didnt do the install correctly.
Check out some Vaistech threads and see what to look for.
Old 10-05-12, 01:54 PM
rominl
exclusive matchup
rominl's Avatar
sounds like loose connector for sure
Old 10-05-12, 03:50 PM
3GS350RWD
3GS350RWD's Avatar
Thanks for the advice guys. It's back to normal now after letting it sit for a few hours. Definitely will contact Vaistech when it happens again. I was gonna start a thread in that forum but still waiting for the approval from the admin.
Old 10-06-12, 11:08 AM
3GS350RWD
3GS350RWD's Avatar
arrrrrrrr.........just thought it was back to normal but it's happening again. This time I am pretty sure it's the head unit not the Vaistech cuz I was listen to radio when that happened. Any one know how to reset this unit?
Thanks,
Old 10-06-12, 12:36 PM
Ziggy716
Ziggy716's Avatar
I would disconnect the vaistech unit entirely and reconnect stock and drive for a few days week or so and see if the problem persists and if it does not you can safely say the unit is at fault. Then simply reconnect vaistech and program again to spec and see if that works.
My 2cents.
Old 10-06-12, 05:52 PM
rominl
exclusive matchup
rominl's Avatar
Thanks,
where in CA are you?
the harness to vaistech contains the power source as well. if it's not done right power can be on and off. happened to a car i have seen already. the vaistech harness is sometimes tricky to work with, it doesn't have the factory harness "snap / click" feel, some people think harness is already all the way in but it's not
of course, it can be the radio dying the with it going in and out, i still tend to think it could be the harness
Old 10-07-12, 05:09 PM
3GS350RWD
3GS350RWD's Avatar
My 2cents.
Thanks! Will try that.
Old 10-07-12, 05:16 PM
3GS350RWD
3GS350RWD's Avatar
In Fremont, CA.
That sounds convincing too me about the loosen harness. It wasn't acting like that before. I will try to reinstall it. Thanks.
Old 10-08-12, 12:43 AM
rominl
exclusive matchup
rominl's Avatar
In Fremont, CA.
ah too bad you are in norcal
yes, take it out and try to push the harness (from vaistech) that goes into the head unit (at the bottom, gray color) all the way in. see if that helps
Old 10-12-12, 11:57 AM
loccsta187
loccsta187's Avatar
this happened to me, CD's wouldnt play, but radio would work fine
i dismantled the console, took the head unit out, fidded with the connectors in the back and it worked fine
then all of a sudden it cut out again
if you take the console out (shifter, cupholders, etc...) you will see a black protected wire going along there
all i had to do was move that around and reseat it and it fixed
also, check the back of the trunk and make sure your amplifier connections are all tight, it is on the passenger side rear of the trunk
MASSMINI
RX - 1st Gen (1999-2003)
02-06-12 04:18 AM
ranorris2
North Texas Lexus Club
10-28-10 12:38 PM
MVLEX
10-26-10 07:47 AM
jewel
04-26-08 01:23 AM
Foyler
07-20-07 03:58 PM
Quick Reply: Audio problem
