Oil change issue
Oil change issue
I have used Mobil Express (synthetic oil) last 2 times for oil change vs. Lexus dealership.
Now on 3rd time with Mobil they can't get the oil filter off......they tell me they needed to order a special Lexus-Toyota wrench.....that concerns me.
Should I let Mobil go ahead and attempt to get the filter off or go back to my Lexus dealership?
Concerned Mobil Express might mess something up and cause a major issue.
I am leaning to Lexus dealership and let a true professional mechanic deal with this.
Thoughts? Recommendations?
Same wrench exists on Amazon and elsewhere at a lot less money than what Lexus dealers sell it for.
But why are you worrying about who takes the oil filter off for?
Are you trying to intimate that somehow the Mobil oil has done something to the filter cover?
The most they can do wrong is damage the cover, which they would replace.
Don't know where your fear is stemming from, but if you have concerns, just talk to them.
I don't do work on my cars.
I just didn't want damage from an a Mobil oil changer on my $35K automobile.
Based on your comments I shouldn't be concerned with Mobil taking care of this.
Thanks.
Thanks.
I bought mine at walmart for $9. The tech probably wasn't sure of himself. On my first oil change I did myself on my car, even with the wrench, I couldn't get the oil filter chamber open. I had to muscle it and when it came loose that was my learning experience. It's just like a tight jar lid, once you get it loose you just screw it off. However in your situation I would just take it to Toyota(cheaper) or Lexus because if they are complaining about an oil filter wrench then they probably won't take the time to replace the o-rings for the new filter.
I don't think the OP says they were complaining - just that it was tight and would preferably want to muscle it off with the correct fitting tool rather than something makeshift.
That's the sign of a good outfit, since a lesser mechanic/garage might've bodged it by using brute force and ignorance.
The OP won't be expected to pay for the tool - it'll be absorbed into the business as a deductible expense, and they'll now have it for future customers, inc the OP returning, they hope.
If the job is quite a bit cheaper than using a dealership, then that makes sense to stick with them.
Thanks!!!!
Theres Oil filter socket kits, the normal O band type filter wrench, a screw driver. I use a screw driver and hammer worst case scenario if i dont have any other way.
But my favorite oil filter removal tool is a channel lock oil filter wrench.
Oil filters are supposed to be hand tightened. The average oil changing person probably does not have enough grip to over tighten it. Over tightening an oil filter with a wrench can cause the O-ring to crush, crack or what have you and cause an oil leak.
Maybe they wanted to charge extra to remove a filter?
This has nothing to do with the type of oil you're using. The first time I changed my oil, I had a ***** of a time getting the oil filter off. I ordered the same Assenmacher Specialty Tools TOY 640 Oil Filter Socket Wrench that was mentioned earlier. Once I got it off the first time, you only need to hand tighten the oil filter. I'm not sure why the dealerships insist on tightening them down so much.
