Audio wiring Help !!!
Does anyone have the wiring schematic for a 2008 gs350 non-ml navi set up. I cant seem to find anything here, only found is wiring! Any help greatly appreciated!!!!!!
Front right: pink +, purple -
Front left: green +, blue -
Center: yellow +, black -
Rear left: black +, yellow -
Rear right: red+, white -
Sub 1: pink +, violet -
Sub 2: blue +, green -
You can locate the pair for the rear because they are together at the amp and the center is separate. You don't want to sum the front and the rear, use one or the other for your input as they can both be full range depending on your dsp settings.
Thanks so much man i appreciate it!!!!!!!
In my IS i had, i used the front driver side only so that if i was listening to music loud and using my navigation it would cut out the bass etc so i could hear directions, guess i will stick to that method once again.
hi im nearly new to the audio scene and i have a 2008 gs350 non ml with navi and i want to add my w6 so
i was told i needed a line out converter and i needed to grab signal from a speaker to get a rca cables
so if im reading correct i could just tap the (pink+) and the (purple -) and i should be fine? sorry i have 5 years of warranty left so i dont want to risk anything! thanks
I would unsolder your + and - for your subwoofer, and tap off of that, that way you can resolder them later onto the sub and still keep warranty.
FYI: While I still had my warranty, Lexus had no problem doing things with my system still in place, so having an aftermarket subwoofer system SHOULD NOT void your warranty.
And Audiobob? HUGE PROPS and THANK YOU for the diagram, I've been contemplating back and forth with myself whether or not these wires are what they are..... Now I can further confirm myself that they are indeed the wires
stiles17
09-01-14 02:27 AM
wwwing
SC- 1st Gen (1992-2000)
07-31-11 11:41 AM
2lowgs
07-03-08 12:30 PM
VSsc400
04-26-04 06:54 AM
