Replacing brake dust shield?
Hi CL,
I have a chronic problem whereby the passenger side front brake dust shield keeps rubbing up against the rotor during left-hand turns, causing an ugly-sounding scraping/grinding noise.
I've tried pushing the shield inwards and sometimes the noise will go away temporarily, but it ultimately comes back. Is there a reason why it keeps getting bent back so that it rubs against the rotors?
I actually ordered a replacement dust shield (special order from California) but when I took it to an independent mechanic to get it replaced, he said he'd have to take the ball bearings out first before being able to replace the dust shield. He then explained that if he took out the ball bearings, I may have to get new ones. He priced the ball bearings out to be around $450 plus 1-2 hours of labour I believe. I don't know much about this kinda stuff so I took him at his word.
The mechanic said he tried to push the shield into shape and the noise went away for a few days, but it's now back so I assume the dust shield has bent back to touching the rotors.
Is what the mechanic telling me correct? Do I need new ball bearings if he takes them out? Is the removal of ball bearings necessary to switch the dust shield? Has anyone changed their dust shield before? Does anyone have any suggestions for me? I've been having this problem off and on for the better part of a year now.
Thanks in advance!
Thanks in advance!
The wheel bearings come as an assembly, nobody takes the bearings out unless they are talking about the bearing assembly in which case I don't know why you would need to replace the wheel bearings just because they were temporarily removed.
So does that mean the assembly can be removed/reinstalled without actually popping out the individual bearings? Meaning the bearing assembly can be removed and re-installed without any fear of the bearings/bearings assembly being damaged and/or needing to be replaced? (Assuming there are no problems with the bearings to begin with.)
Thanks for your reply. I've been constantly pushing the shield back with a long screwdriver but it's only a temporary fix. It always comes back into contact with the rotor after a few days. After about a year of this (and when lazy, driving with it in contact with the rotor), I want to actually fix this problem once and for all.
And I am using OEM rotors.
What the mechanic told you is only partially correct. It's true that you have to remove the wheel bearing in order to remove the brake dust shield, however the GS has an enclosed wheel bearing, meaning there's only 4 bolts holding the wheel bearing to the hub as opposed to the press-in style bearing he is talking about
the bearing is shown in this diagram
http://lexus.sewellparts.com/oem-cat...S350-2007.html
The dust shield fits between the hub and the wheel bearing, so realistically there's no need to replace the bearing as it in an enclosed unit,
Hope that helps
Hope that helps
Just take a long screw driver, and a big hammer, Bang it a few times hard to push it back, make sure the edges of the brake dust shield are not curved too close to the rotor and you should be fine. I had same issue on more then one occasion and a long screw driver and a hammer did the job for me. It is also weird it only happen when turning the wheel all the way to the left or to the right. Now its silent as a mouse.
Thanks for all the advice guys. This morning it wasn't making any scraping sounds so I'm truly confused.
If it makes any more noise, I'll just use a screwdriver and a hammer this time (before I would just push in with the screwdriver...) and see if that helps.
Mikeyy, thanks for the information! I don't know much about this kind of stuff but from what you and BinaryJay have said, it seems that since it's a whole assembly being removed instead of individual bearings being popped out, it shouldn't pose a problem to remove and reinstall. I will keep this in mind the next time I go in for an oil change and ask my other independent mechanic his opinion.
Hi CL,
Thanks in advance!
Thanks in advance!
I'm curious what caused the brake dust shield rubbing against the rotor during the turn.
Brake dust shield & wheel bearing are covered under EW. Let see what deal says when I bring the car in next week.
