Old 12-15-14, 03:08 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Tires and Wheels Guide
Print Wikipost
Low tire pressure warning light (blinking)
Old 06-16-12, 02:38 PM
Droberts12
Droberts12's Avatar
Default Low tire pressure warning light (blinking)
2006 GS 300 awd 72,000 miles
Tire pressure light came on filled all tires including spare to 35 psi light still blinking, has anyone had this issue? Has anyone tried to disconnect battery to reset light, or is a trip to the dealership my only option.
Thanks
Old 06-16-12, 04:49 PM
Boron
Boron's Avatar
You could phone the dealer and ask to speak with the service dept.
They may be willing to share a trick or two to rule out the sensor in one of your wheels being faulty.
Try first, the worst that'll happen is they ask you to bring the car in to be checked (they may charge for it), which you can put on the back burner until Google or someone else chimes in with something to try.
Old 06-18-12, 04:34 PM
L3XOTIC
L3XOTIC's Avatar
TPS Light is NOTORIOUS. I have a used car dealer and it drives me insane with all these cars/trucks with the TPS light on.
Old 06-18-12, 07:51 PM
XxGoKoUxX
XxGoKoUxX's Avatar
Have you tried bumping up the pressure to 40? TPMS sensors are not built to SPEC of your tire, but programmed to whatever psi was set on it previously. If your vehicle is 2nd hand, it might of had a higher psi setting than nominal, so try bumping it up to 40psi and see if it goes away! I know i have 35 or so all around (not comfortable as 32, but it gets the job done).
Old 06-18-12, 11:43 PM
arnieosp
arnieosp's Avatar
Thanks
If your pressure was too low, you would have a solid light. Blinking light indicates system problem. It could be a battery goind dead inside one of the sensors, ir the sensor itself gone bad. In my case they just re-initialized the system, but I had to take it to the dealer under warranty.
If it is a dead battery, before buying a new sensor, you can try to replace the battery. Take a look at the post #6 here.
Old 12-16-15, 04:40 PM
memokc
memokc's Avatar
Mine started blinking all of the sudden today as well, all my tires have the proper level of air. It might be a TPMS battery but what is this button people are referring to under the steering wheel that may have accidentally been pushed? What is it labeled etc so I can check to see if I may have inadvertently pushed it with my knee or something first before I go to Discount Tire. The TPMS sensors they install at Discount will work with our factory system I am assuming, I have a 07 GX 470 or do I need to go online and order Denso TPMS sensers? Thanks in advance!
Old 12-20-15, 10:58 AM
z2g2gs
z2g2gs's Avatar
Discount tire sensors will work. 60 bucks installed and reset to system. They will check all your sensors to make sure they are working, or to find the defective ones, no charge for this.
Old 12-20-15, 11:34 AM
anomale
anomale's Avatar
Check the button under the dash If a passenger kicked it by accident it could cause this issue. it's under the dash next to the center console.
Old 07-01-16, 02:09 PM
Brabusx2
Brabusx2's Avatar
my car had that issue once,
the TPMS battery only last like 7-10 years or 100k miles before they need to replace completely, not expensive around $50-60 any tire shop can do it and program it for you
Huskers 22
ES - 5th Gen (2007-2012)
10-31-19 05:02 PM
ingoodtime
11-13-11 04:49 PM
lifeisgood
09-23-06 06:08 AM
sidgriggs
09-21-06 08:17 AM
firstls430
03-17-06 05:21 PM
Quick Reply: Low tire pressure warning light (blinking)
