Tpms?
Old 06-01-12, 07:01 PM
xxrap985xx
xxrap985xx's Avatar
Default Tpms?
Hey guys,
I have aftermarket rims on and I don't feel like spending money on toms sensors for them can I have the notification for the tpms turned off?
Old 06-01-12, 07:36 PM
pqn628
pqn628's Avatar
No way to turn it off. Of you have a discount tires in your area, they have some for a decent price.
Old 06-01-12, 11:33 PM
M K S
M K S's Avatar
Sadly, there is no way to disable the TPMS on these cars. The best solution I found was to just buy a second set of sensors and have them programmed into the ECU - then all you have to do is toggle between the two sets when running different wheels.
The only other option is the pipe bomb, and running that in your trunk.
Old 06-02-12, 02:59 AM
XxGoKoUxX
XxGoKoUxX's Avatar
although pipeboomb is the easiest alternative (not the explosive kind)
You can run a bypass if you can manage to get the wiring harness layout to DO this mod BE AWARE: this is for tundra rigs, not GS rigs
http://www.tundratalk.net/forums/tun...-blinking.html
here's a DIY TPMS pipe bomb setup too, for your reference:
https://www.clublexus.com/forums/is-...pipe-bomb.html
Old 06-02-12, 01:35 PM
xxrap985xx
xxrap985xx's Avatar
Thanks for the info
87vertgt
12-13-18 10:13 PM
Myrix
Wheels, Tires & Brakes Forum
07-05-16 08:59 PM
ctatum7
03-24-15 07:18 PM
SNiiP3R
01-09-15 03:41 AM
BoostAddct
06-19-07 06:43 AM
Quick Reply: Tpms?
