headlight hazing up.
Old 04-01-12, 09:29 PM
xmike714x
xmike714x's Avatar
Default headlight hazing up.
my gs350 headlight is hazing up. it started to do this right after we had a horrible rain for a couple of days. is this covered under our warranty?
Old 04-02-12, 01:28 PM
loccsta187
loccsta187's Avatar
the top of the headlight housing? you have a white'ish film right?
I used plastix polish (megiuars) and with a little bit of rubbing it came right off
Old 04-03-12, 01:50 PM
mynes09
mynes09's Avatar
I wonder also if it's covered under warranty
Old 04-03-12, 02:07 PM
j0emama
j0emama's Avatar
I highly doubt something like that is covered by warranty. Certainly not covered under CPO warranty.
My headlights are starting to have the same affect, but only slightly after 5 years (2007 GS 350). Easy fix and comes right off if done right.
Old 04-03-12, 03:13 PM
Boron
Boron's Avatar
Hazing or condensation?
Can't see rain affecting the outer surface, which can be polished up to full clarity.
If you mean condensation forming on the inner surface, then the seal between the front and rear housings has started to fail, allowing moisture or cool air to enter.
Not sure if the gasket can be bought separately, you might just have to put some clear silicone sealant around the joint.
Old 04-06-12, 03:27 PM
Brabusx2
Brabusx2's Avatar
it always happen if your car sit under the sun for too long,
easy trick,
TOOTHPASTE
squeeze it on a papertowel and rub rub rub on the lights and then damp cloth wipe it off, now your GS headlight has cavity control!!!
Old 04-09-12, 09:37 AM
j0emama
j0emama's Avatar
easy trick,
TOOTHPASTE
I've heard that works well. Any success yourself?
Old 04-15-12, 05:56 AM
cubabarber
cubabarber's Avatar
Toothpaste?? Clever... Didnt kno that....
I also did the mcguires plastix... I Applied it like wax... Left it on for about 5 and rubbed it hard and it worked good... Just go over the parts that dont come out over and over and eventually they should... And then i waxed it after with the mcguires carnauba wax.. came out good
Old 04-15-12, 10:12 AM
Dawa
Dawa's Avatar
the toothpaste works because it is somewhat of a fine abrasive. same thing with plastix. both of those might work for a while, but eventually youll need to go deeper than both of those fine abrasives can go. youll have to go the sandpaper route. google it. basically you start wet sanding initially with a coarse paper, and then switching to a finer and finer grade paper each time. just make sure you cover the surround areas (fender, hood, bumper) with painters tape or the like.
Old 04-15-12, 12:38 PM
worker
worker's Avatar
sadly mine is yellowed and it seem cracks a bit all over, sign of the plastic going bad.
And just the other day I saw a tiny bug flying inside after I came back from the park. I thought the headlight is sealed, I guess not.
Old 04-15-12, 04:35 PM
Valley101
Valley101's Avatar
Default Headlights Hazing.
I do my light lenses about once a month with a product Honda makes for the motorcycle windshields. It is called Plexus. If you use it periodically you should never have a problem and if you do have a problem it will help it greatly. Have been using on my Harley (2007) Road King Classic, and it still looks like new. It you have dried on bugs it will desolve them easily. It cost about ten dollars for a spray can, but it last forever, as you use very little on each application.
Old 04-15-12, 10:07 PM
SoKali-RX
SoKali-RX's Avatar
Hazing use meguiars plastix, condensation you're out of luck, it's only going to get worse, probably a leak somewhere from a crack
Old 04-30-12, 01:26 AM
Duonghtx
Duonghtx's Avatar
Bought the 3m headlight restoration kit worked well, came with a buffer pad you attach to your drill to buff it all out. Made my lights look brand new.
Old 04-30-12, 04:32 AM
XxGoKoUxX
XxGoKoUxX's Avatar
to prevent this from happening again, you actually have a few choices.
A) For the ballsy peoply, tape up your car, get a can of spray-clear, and clear your headlight lenses, do a couple coats, sand down, polish, and wax or sealant.
B) You can also just simply sealant (need about 2-3 applications maybe) once a year.
I've done the "A" choice on many of my customer's cars, along with my gf's stepfather's Accord and my best friend's prelude. Their cars were immaculate after 2 years. None of my customers have ever complained to me again about their cars hazing up.
Old 04-30-12, 04:55 AM
ITWORKS
ITWORKS's Avatar
I used a product called Crystal View. Good stuff, brings sealant for the final touch
Quick Reply: headlight hazing up.
