4300K vs 5000K but it doesn't look right....
Old 03-31-12, 07:36 PM
jonnyxboi
jonnyxboi's Avatar
Default 4300K vs 5000K but it doesn't look right....
My driver side bulb was starting to shut off, so I decided to replace both headlights with 5000K bulbs. Not thinking too much about it, I just went to VHIDS and got apair for $25. I finally got them in
this morning. As I drove home tonight, I noticed that something didn't look right.
I know I'm going to sound like a total noob, but that's because I am. My headlights used to light up the road evenly across. Now it looks like they're pointed straight at the ground 5 feet in front of the car. When I make right turns, I don't even see the AFS turn anymore. Both sides still go up and down when I turn on the car. Could I possibly have installed them wrong? Are the bulbs themselves supposed to be rotated a certain way or could this be because I paid $25 for a pair of bulbs?
This is precisely why I hate messing with cars. You start to freak out and pay attention to things you never did before.
OEM
5000K VHIDS
OEM
5000K VHIDS
5000K Beam Pattern
Last edited by jonnyxboi; 03-31-12 at 07:39 PM. Reason: adding picture description
Old 03-31-12, 08:36 PM
Mesca
Mesca's Avatar
Paying $25 for 2 HID bulbs sure sounds like you're asking for trouble. I'd recommend Garax bulbs, spent about $85 had them for over year and a half now and no problems. Get them through a vendor here, if they crap out they'll be more than willing to help you out. Although I had 6000K the higher you go up away from 4300K the less output you have, but it's not a big deal.
Old 03-31-12, 09:12 PM
Hoovey689
Hoovey689's Avatar
"cheap" really shows with HID bulbs from my experience. I'd also recommend Garax or MTech. I DO NOT recommend DDM Tuning
Old 04-01-12, 01:04 AM
jonnyxboi
jonnyxboi's Avatar
had a couple beers and then decided to try it again. Looks like they're ok now...
Attached Thumbnails 4300K vs 5000K but it doesn't look right....-img_2273-1-.jpg
Old 04-01-12, 03:57 AM
bigblack06
bigblack06's Avatar
What is the brand of bulb your using, and your headlight is a little foggy maybe that could be the reason. I would say go with Garax or Morimoto, the output is alot better.
Old 04-01-12, 04:36 AM
tbilisi79
tbilisi79's Avatar
Problem with the world today is, everyone is a few drinks behind!! "Humphrey Bogart"
Old 04-01-12, 06:05 AM
Boron
Boron's Avatar
Why oh why are you running with fog lamps lit up, when it's not even the remotest bit foggy?
I could understand wanting as much light as possible if you were driving a forest stage in a Grp A rally car, at night - but you're not!
You do realise using fog lights when there's no fog to reduce visibility is seriously uncool, and will have most normal drivers thinking "<insert word of choice>!".
Regarding the bulb choice - price doesn't always dictate quality, but could indicate the difference between sufficient lumens and lack thereof.
The colour temperature difference should be immaterial between 4300K and 5000K other than crisper, more like natural daylight look.
Only when you start heading toward 6000K and above, does the output of usable light drop because of the dominance of the shorter blue wavelength.
Old 04-01-12, 07:48 AM
jonnyxboi
jonnyxboi's Avatar
I bought a pair of VHIDS. I really didn't think the bulb mattered, but I can definitely tell the difference now. I actually didn't realize that they were only $25 a pair and ended up buying 4...thinking I was paying for 2. I might just get rid of them and go with another bulb, but then again I dread having to change bulbs on a car.
I appreciate your concern about why I run fog lights on a clear night and how that impacts stranger's perception of me. Thank you for your input.
Old 04-01-12, 08:47 AM
bigblack06
bigblack06's Avatar
I run my foglights with no problem, without fog. Does it really matter its not like it will blind anyone, hence why most people get there foglights done to put them on with there headlights!
Old 04-01-12, 08:51 AM
onephatguy
onephatguy's Avatar
I'm going to have to disagree with your point of view on that. Most cars I see are running with their fogs on. It doesn't effect on coming traffic, it's just about personal taste. I think it is cool looking. Where are you from? Could be different taste in your area.
Old 04-06-12, 08:19 PM
jonnyxboi
jonnyxboi's Avatar
so...replace the 3K's with xenon depot's 5K fogs. I also finally got the low beams in correctly. Just thought I'd share.
Attached Thumbnails 4300K vs 5000K but it doesn't look right....-img_2290.jpg   4300K vs 5000K but it doesn't look right....-img_2291.jpg
Old 04-06-12, 09:23 PM
bigblack06
bigblack06's Avatar
Looks 10x better.
Old 04-06-12, 10:17 PM
06ausiecar
06ausiecar's Avatar
The fogs on this car are kinda just for looks. My GTO will actually over take the headlights, my moms 4runner and friends new Tc project way far out to the side of the car but the lex just is kinda there. I understand fogs aren't suppose to be on unless needed but the only distraction on oncoming cars is the yellow color not the blinding. At lease on the 3GS. (maybe blinding with a hid kit) Some I could understand. It's kinda like a German car leaving the rear fog on. Not purposeful but not really hurting anything.
kumquatism
03-18-16 01:28 AM
talwang
RX - 3rd Gen (2010-2015)
33
03-24-14 04:52 AM
bigblack06
11-12-13 07:10 PM
RastaRacer
10-01-13 02:23 PM
joeazy187
SC- 1st Gen (1992-2000)
16
11-03-09 10:19 PM
Quick Reply: 4300K vs 5000K but it doesn't look right....
