Headlights periodically go off
Old 03-31-12, 11:34 AM
Dallas300
Dallas300's Avatar
Default Headlights periodically go off
I'm having a strange problem. While driving with my headlights on, one or both of my headlights periodically turn off. They turn back on when I turn the headlight switch to off and back on again.
Does anyone know what is causing this and how to resolve this problem?
Old 03-31-12, 02:21 PM
tunedis95
tunedis95's Avatar
Mine does the exact same thing. Super annoying. Help us!
Old 03-31-12, 05:07 PM
LADavidGS
LADavidGS's Avatar
hid bulb or ballast or both.
Old 03-31-12, 06:24 PM
imadesign
imadesign's Avatar
mine does the same,, left side only..im getting new bulb soon
Old 03-31-12, 07:30 PM
mydawgz
mydawgz's Avatar
ballast is my guess. A bulb would prob stay dead! lol.
Old 04-01-12, 07:36 AM
M K S
M K S's Avatar
Mine were doing the same thing. I replaced both bulbs and that fixed the problem.
Old 04-01-12, 08:10 AM
Dallas300
Dallas300's Avatar
When I replace the bulb is the ballast part of the bulb replacement? I'll place an order for replacing both bulbs.
Any suggestions on what after market bulbs to use or should I use factory bulbs from the dealership?
Thanks for the responses.
Old 04-01-12, 08:56 AM
bigblack06
bigblack06's Avatar
You can go with Morimoto or Garax OEM if you wish to stay stock but for that you can go on amazon. No the Ballast is not part of the bulb that is a seperate part that needs to be ordered but I would check to see if it is the bulb.
Old 04-01-12, 01:21 PM
liv2drift
liv2drift's Avatar
I had the problem and replaced the bulbs and the problem went away.
Old 04-01-12, 04:53 PM
SCGS350
SCGS350's Avatar
Your bulbs are bad, replace them and you should be fine. I went with Morimoto bulbs from the retrofit soure and havent had any issues.
Old 04-02-12, 08:49 PM
Dallas300
Dallas300's Avatar
I just ordered 2 Phillips D4S Xenon HID bulbs from Amazon for $100. I'll let you know how well they work after I receive and install them
GRZMNKY
01-06-12 09:14 AM
cestjoel
05-29-11 06:45 PM
Jsy622
10-01-09 09:38 PM
LiqrSicc
RX - 1st Gen (1999-2003)
08-11-06 01:37 PM
HustleHard
SC- 1st Gen (1992-2000)
12-25-05 01:32 PM
Quick Reply: Headlights periodically go off
