Who is running 245/35 & 275/30-20
Old 03-24-12, 01:16 PM
msgs350
msgs350's Avatar
Default Who is running 245/35 & 275/30-20
Hi, just wanted to know who is using this set-up with what rim specs? Any fender mods? I'm asking because although it is "out of spec" and bigger than stock, They run cheaper than other tire sizes. Thanks...pics would be great!
Old 03-24-12, 03:07 PM
sourwich
sourwich's Avatar
im running on Ace 245/30/20 offset 35 and 275/30/20 offset 40,F sport spring 1" drop,the front is ok,rear touch little bit when highspeed,i didn't do rolling...just remove small platic,if offset is >40 i think it will be ok.
Old 03-24-12, 08:07 PM
jmtamu
jmtamu's Avatar
I'm running it as well on +35 and +40. I rub just a tad when the wheel is completely cranked backing out of a driveway in the front.
In the back, I used to rub a little more on bumps but I think I've worn down the lining so much now that it rarely does now unless I've got people in the backseat which is rare.
No rolling or shaving for me.
Also have a 1" drop on F-Sports springs.
Old 03-26-12, 11:13 AM
tmoore8878
tmoore8878's Avatar
I know there are not many tires available, but wouldn't a 235/35/20 be a better match for the 275/30/20 if you want to keep the OD the same? I'm gonna order a set of Vossens within the next 2 weeks and I can't for the life of me decide which tires to run.
Old 03-26-12, 11:51 AM
msgs350
msgs350's Avatar
You are correct and i have ran those before. I'm asking because i already have 245/35-20 tires already. I was just thinking that 245/35 and 275/30 are sold/recommended often with wheel packages.
Ideally, i'd like to use the sizes you mentioned.
Old 03-26-12, 12:33 PM
IXI187IXI
IXI187IXI's Avatar
yes they are mostly sold with wheel and tire packages but it doesnt mean the are correct for our car. you can use them if you like but you may run into some rubbing. the one i see all the time is what's mentioned above with the front rubbing on full turns.
Old 03-26-12, 12:59 PM
msgs350
msgs350's Avatar
^^ true also. Just trying to use what I have. My front fenders are shaved though.
2inch drop with 20x9 +38. What you guys think?
Old 03-26-12, 04:12 PM
mr3gs300
mr3gs300's Avatar
Im running those specs on mine just like said before will rub when make turns, but easliy fixable just take a heat gun and reshape fender liner and as for the rear you can either roll or shave em
Lakersfan
12-01-16 10:03 AM
Charlie088
05-17-11 10:14 PM
ECUgs430
06-21-09 08:09 PM
ek9max
04-18-09 12:02 AM
TIS250
09-18-07 08:52 PM
Quick Reply: Who is running 245/35 & 275/30-20
