Luminics Halogen Yellow fogs melting my lenses
Old 03-18-12, 06:39 PM
adamz28
adamz28's Avatar
Default Luminics Halogen Yellow fogs melting my lenses
I'm running a set of Luminics Halogen Yellow fogs. These are #9006 12V, 55W, 13 W. I notice these bulbs get very hot and my lenses are now warping. Has anyone else had a problem with these bulbs melting their fog light lenses?
Thanks
Old 03-18-12, 08:10 PM
passnu2
passnu2's Avatar
55W is too much...
Old 03-18-12, 09:19 PM
adamz28
adamz28's Avatar
Originally Posted by passnu2
55W is too much...
What wattage should I use? Thanks for the help.
Old 03-18-12, 09:38 PM
passnu2
passnu2's Avatar
have or would you consider upgrading to HID's? If so its what I would suggest. Our vendor XenonDepot would be my suggestion. Pretty sure I read another member having the wires and harness melt from the 55w bulbs.
Your car is very picky with what bulbs or kits you use. Either way contact Steve @ XenonDepot and he can give you some options depending what your looking for.
Old 03-18-12, 10:17 PM
LADavidGS
LADavidGS's Avatar
use 35w instead 55w
Old 03-18-12, 11:14 PM
06ausiecar
06ausiecar's Avatar
35 watt 3000k kit does the job in mine.
Old 03-19-12, 07:01 AM
XxGoKoUxX
XxGoKoUxX's Avatar
ouch, how are you gonna go about fixing this problem, if you ARE going to fix it OP?
Old 03-19-12, 07:21 AM
IXI187IXI
IXI187IXI's Avatar
55W is too much...
55w should be standard for a halogen bulb. even the stock lexus bulbs are like that.
Old 03-19-12, 08:12 AM
bigblack06
bigblack06's Avatar
Never heard the melting of the housing but I know the Nokya yellow fogs I had before where way to hot, I think they were 75 watts, I never had a problem and they would steam when it rained. I had a wiring harness so it wouldn't melt the wiring. I will say Im glad I changed them cause they would scare me. yeah stock is 55W as he said ^
Old 03-19-12, 09:22 AM
LexFather
Guest
Posts: n/a
Yeah my Nokya's burned my housing...went with an HID kit like I should have the first time and have had no issues
Old 03-19-12, 09:45 AM
TWong350
TWong350's Avatar
As others have said, HID kits FTW.
Old 03-19-12, 10:12 AM
passnu2
passnu2's Avatar
my bad guys I thought it was 35w? I still suggest going HID and losing the 55w aftermarket bulb.
Old 03-19-12, 11:00 AM
IXI187IXI
IXI187IXI's Avatar
according to sewell, its 51w
http://lexus.sewellparts.com/oem-cat...S300-2006.html
Old 03-19-12, 11:47 AM
ghd8989
ghd8989's Avatar
Where did you buy these at?
Old 03-19-12, 01:27 PM
XxGoKoUxX
XxGoKoUxX's Avatar
any of the local vendors can supply you with an HID kit.
Quick Reply: Luminics Halogen Yellow fogs melting my lenses
