front spacer questions
Hey guys,
i need your help.advice...
Im looking for spacers for my front wheels.. i think they are too in compared to my rear rims because of the straggered set up.. what do you guys recommend??
have 8.5x20F, 10x20R
GS350awd...
GS350awd...
what are the offsets of the wheels and the tire size you are using? all of that will depend on what size spacer you would need and/or want to use.. Also rolling fenders may be required as well.
if your lowered and your looking to push the wheels out, you will certainly rub with those tires.
if your trying to get your fronts to sit out to match the rear, we need to know the rear specs as well. you could get away with a 10mm spacer, probably with very minimal work
