Need some opinions on tire sizing...
Old 01-30-12, 08:49 AM
Slamking18
Slamking18's Avatar
Question Need some opinions on tire sizing...
Whats up all? Spring is quickly approaching and I am getting ready to order a set of staggered Vossen CV3's. I'm having a bit of trouble picking out the sizing of tires and could use some help/opinions on this topic. I am definately wanting to go with the Hankook Ventus V12 tires because they are highly rated and very inexpensive compared to other brands.
With this being said, I want to stick as close to OEM sizing and from what I have researched, the perfect combo is 245/30/20 (fronts) and 285/25/20 (rears). I contacted Hankook and they notified me that there is no production scheduled at this time for the 285/25/20's which means we probably wont see them for at least another year.
I have seen some people go with the 245/30/20 (fronts) and 275/30/20 (rears) combo in which the rear is about 1" taller than the front but have not heard of any issues with this.
I also found that Hankook makes a 295/25/20 which shows to be within OEM spec based on 1010tires.com, but shows to be another 1/2" wider .
What do you guys think? Given that I go with 245/30/20's in the front, should I get 275/30/20's or 295/25/20's for the rear? Also, do any of you know of issues with either of these sizes that I should concern myself with?
Any other sizing recommendations welcome, but I want to do as little modification as possible to my car.
Thanks for the help all!
Old 01-30-12, 08:52 AM
LIMS407
LIMS407's Avatar
toyo makes tire size you are looking for,,
Old 01-30-12, 09:50 AM
Slamking18
Slamking18's Avatar
Yeah, I know.... They are pretty pricey compared to the Hankooks and I'm not real sure of their ratings either... Thanks.
Old 01-30-12, 09:55 AM
IXI187IXI
IXI187IXI's Avatar
decent tires arent cheap especially when your going with a wide tire for the rear
Old 01-30-12, 01:25 PM
mr3gs300
mr3gs300's Avatar
yeah like they say you get what you pay for, thers other reasonable price tires out there you can choose, like falken nankang nitto, plus I think with those 295 youre gonna have to do some serious rear fender modding
Old 01-30-12, 04:58 PM
Slamking18
Slamking18's Avatar
Thanks for the comments guys, but I guess I am kind of confused with them... With most of the comments, it seems as if you are all saying the Hankooks aren't good. I have heard nothing but good reviews about these tires and that coupled with the lower cost, I thought it was a no brainer to get them. Based on the 1010tires.com calculator the 295's are only 0.4" wider than the 285's... I guess I dont know how close the 285's are from the edge to know if its a big deal so if anyone can comment on this, I would appreciate it. I think I am still on the fence between the 275/30's and 295/25's cause I have heard alot of good reviews with the Hankooks and really dont want to spend the $$$ for the names of the others especially since I will only be driving on them for 3-4 months out of the year.
Old 01-30-12, 05:14 PM
07LXgs350
07LXgs350's Avatar
I got hankook v12s on my 19" f sports and I couldnt be happier with them.
Old 01-30-12, 05:55 PM
lkapimp216
lkapimp216's Avatar
Just go with the nankangs, cheap tire you can flip them to if your running negative camber slightly noisy but cheaper and they stretch well if your going for that. I have a 225/30 and 245/30 stretched but my car is rwd and pretty much a toy and not very functional as a daily driver
Old 02-01-12, 10:41 AM
Slamking18
Slamking18's Avatar
Well, since I haven't really recieved any useful information yet, I think I am just going to order the wheels soon and have to test fit them without tires and measure to see if I have clearance for the 295's as this would be my preference over the 275's.
For any of you that are running a set of 285/25/20's, I would appreciate it if you could measure your clearance (inside and outside) and report back as this would tell me whether an extra 10mm is really a big deal or not.
Old 02-01-12, 11:06 AM
IXI187IXI
IXI187IXI's Avatar
what useful information? your asking about something that is personal preference. also theres way more to wheels than just the tire size. you need to take into account the width and offset of the wheels which will affect where the tire sits.
Old 02-01-12, 11:20 AM
louisp_p
louisp_p's Avatar
Have you ever consider Vredestein Ultrac Sessanta? Somebody told me they make great tires and they do have the size you want,285/25/20, on ebay. I am also thinking to get Vossen CV3 and therefore is also doing some research on tires. Does anyone know if 285/25/20 will rub at the rear without any modification?(I used to have 275/30/19 and have no issue)
Old 02-01-12, 12:32 PM
Brian@Vossen
Former Sponsor
Brian@Vossen's Avatar
Another thing to remember is based on tire tread, design etc we have noticed that some tires fit and others do not. Mike in Chicago I believe was the first with 295s on his 3GS with no rubbing issues (not sure what tire he ran).
Old 02-01-12, 02:52 PM
Slamking18
Slamking18's Avatar
I have mentioned that I am deadset on getting the Hankook Ventus V12 tires and am debating between the 295/25/20 or 275/30/20 sizes and have got nothing but recommendations for different tires... Good point on the wheel size; I mentioned that I am getting a staggered set of Vossen CV3's, but did not specify anything else. I will be getting the 20x9 +38 for the fronts and 20x10.5 +45 for the rears.
I have not heard of them, but will do some research on them. I have talked with a couple other members running the 285/25/20 and have been told there are no rubbing issues. The only mod you may have to do is roll your fenders if you are dropped some.
Thanks for the heads up on this. Is there any way to figure this out ahead of time? I didn't know if the manufacturer's release specs with that type of info. I used 1010tires.com's sizing calculator and it showed the 295's to have a width of around 11.4" i believe.
Old 02-01-12, 09:46 PM
06ausiecar
06ausiecar's Avatar
Mike had 255's up front 295's in the rear with shave quarters. Without the shaved quarters it would have rubbed. I believe his works were close to typical vossen offsets. I have his old car. 20x10.5 rear rim also I believe. I have Toyo t1r's on my GTO and love them! 245/35 19 up front 275/30 19 in back. 19x8.5 fronts 19x10 rears. 275's are stretched on the 19x10's. Great tread wear, quiet and handles great in dry and wet. I've got around 15k on mine. Lowered 2 inches. If I had put my camber kit on earlier I would expect to get 25-30,000 miles out of these tires. Spirited driving. Highly recommend
Old 02-02-12, 11:08 AM
Slamking18
Slamking18's Avatar
Doesn't shaving and rolling get you the same results basically? If so, I think I would be good with the 295's... I was planning on rolling the rear fenders no matter what when getting the 20x10.5 wheels.
Quick Reply: Need some opinions on tire sizing...
