AFS light blinking...?
Old 12-09-11, 10:55 PM
NYDesi80
NYDesi80's Avatar
Default AFS light blinking...?
Just changed my HID bulbs out since one was burnt out and also upgraded to HID fogs while I was at it. Everything went more or less smooth. After driving for an hour or so, the AFS light started to blink but went away after I turned the car off and restarted it and then pressed the AFS button on/off... only to come back on again after a short while later.
What gives?
I did a search.. and no I did not lower my car. Just replaced my HID bulbs and installed HID fogs. I did not remove the bumper to do the install either. I'm not sure on how the AFS system works.. so don't know how to trouble shoot... any advice?
Old 12-10-11, 12:12 AM
adamls2
adamls2's Avatar
Did you try disconnecting the battery?
Old 12-10-11, 06:34 AM
passnu2
passnu2's Avatar
^ thats not going to correct the issue.
Something must not be installed correctly. Go back and double check your work to make sure the bulb is in exact and that the spring retention and everything else is on correct. Also what direction are you turning when its tripping the AFS system? This should help determine what the problem may be when you open them up to see what its hitting or rubbing on.
Tnguyen9i6
03-01-15 08:34 PM
wilsonwho
11-03-13 09:54 PM
bwl
03-22-12 10:10 AM
GS3.0
11-04-04 12:01 AM
GS300.ru
Lighting
03-15-03 09:49 AM
Quick Reply: AFS light blinking...?
