Back of head rest constantly opening up
Old 11-12-11, 07:08 PM
turbon50
turbon50's Avatar
Default Back of head rest constantly opening up
Does any one have a problem with the back of their head rest opening and exposing the inside? Every time my girlfriend uses the car and the headrest goes up, it slowly opens the back of the head rest. So I have to keep on pushing it back up and fixing this. How can I make it so it doesn't keep falling?
Old 11-12-11, 11:56 PM
GS350Lexus
GS350Lexus's Avatar
Um the headrest moves forward and back also not only up and down.
Old 11-13-11, 06:48 AM
turbon50
turbon50's Avatar
So you mean it's normal for the headrest to expose the inside of the plastic and the leather? When it does this it looks broken and won't seal up until I push the plastic part back up. If this is normal can you show how your headrest looks like this? The picture I showed doesnt show it open as I just pointed to the area that opens.
Old 11-13-11, 09:53 AM
GS350Lexus
GS350Lexus's Avatar
K the plastic piece should be stationary, only the leather part move forward and back. If the plastic piece holds on the clips and keep coming out then you need to replace the clips so it wont come out. Last time i remember that piece is rock solid on the seat where unless trying to take it out wont have it come out.
Old 11-13-11, 09:57 AM
moose66
moose66's Avatar
Aren't the headrest some special whiplash protection style, where they have to be reset if activated? There may be another post on this site talking about the resetting of a headrest after it has been activated. Sounds like that may be what is going on with you. Just a hunch.
Old 11-13-11, 03:09 PM
turbon50
turbon50's Avatar
Do any of you know how to take off the headrest off the seat? I know the button allows you to raise and lower it, but it won't come off.
Old 11-13-11, 03:21 PM
Justin2JZ
Justin2JZ's Avatar
The headrests are active and they do move back and forward but the back is not supposed to move and there shouldn't be anything exposed. You mind taking a picture when it does move and expose stuff to clarify?
Old 11-19-11, 02:49 PM
turbon50
turbon50's Avatar
This is the pic. I have to push it back up and in every time it out goes down. Any idea why and how to fix this?
Old 11-19-11, 04:25 PM
Justin2JZ
Justin2JZ's Avatar
Yeah that's not pose' to happen. Just buy another headrest.
Old 11-19-11, 09:28 PM
GS350Lexus
GS350Lexus's Avatar
Lol just buy another headrest, Yes that is defiantly not suppose to happen. Check and see if u can find maybe some bad clips that don't hold it in place and have them replaced. Or its not something you will ever take a part put few drops of gorilla glue, maybe even silicone. Replacing the whole headrest is a lot of money I defiantly don't suggest that.
Old 11-19-11, 09:58 PM
XxGoKoUxX
XxGoKoUxX's Avatar
I could be wrong because I've never seen it taken out, but those clip ends where the clips attach too look really bent, i'd bend it the other way and see if that works
Old 11-20-11, 09:04 PM
bigblack06
bigblack06's Avatar
I dont think the headrest can come off, I think the headrest like others have said moves but I think thats only the Drivers side.
Old 11-20-11, 09:57 PM
Stormforge
executive matchup
Stormforge's Avatar
wow, that's the first time i've seen a headrest like that. definitely should not look like that at all. i would recommend and check with your dealer to see if you can get this fixed under warranty (or if out of warranty, get it fixed under good will).
Old 11-21-11, 01:42 PM
ccrochet
ccrochet's Avatar
Im have the same issue with my gs430. When i move the seat from wifes position to mine it opens up. Let me know if you get a fix.
Old 11-21-11, 02:32 PM
turbon50
turbon50's Avatar
Yeah. This is kinda irritating. The clips that are visible aren't broken. The grey part actually clips over on to the black piece that is hard to see. It would be easy to see whats wrong and fix it if I could get the headrest off of the seat. If anyone knows how to get the headrest off please let me know as my car isn't under warranty any more.
warminwisc
04-16-19 06:39 PM
sinister2c
06-27-08 01:10 PM
bruce van
SC- 1st Gen (1992-2000)
14
04-11-06 09:21 PM
XMisterCleanX
IS - 1st Gen (2001-2005)
16
09-03-02 01:42 AM
Quick Reply: Back of head rest constantly opening up
