Need some advice.... (wheel/tire related)
Old 09-25-11, 10:25 PM
Lexiss_sc430
Lexiss_sc430's Avatar
Default Need some advice.... (wheel/tire related)
Hey Guys,
I picked up a set of wheels for my sisters 2010 GS350, and I need some help deciding on what tires would be the best for this application.
I have already test fitted the wheels on the car, and they fit without any issues.
what I would like to do, is get the best possible tire package, that offers the least amount of rubbing while also having enough meat on the wheels to protect the rims.
Here are the specs,
Lowenhart LD5
20 X 9 ET 40
20 X 10 ET 44
now I was thinking of running a
245/35/20 in the front
275/30/20 in the rear
The car is not lowered and will most probably stay on the oem factory suspension.
I would like to avoid things like cutting the fender or having to roll them.
What do you guys think? whats the best tire setup for these wheels on a GS?
TIA
BTW: I have already read through the wheel sticky and a few dozen posts regarding aftermarket wheels, I just want to make sure I get the correct sizing for her as since I really cant return tires once I have mounted them on the car.
Attached Thumbnails Need some advice.... (wheel/tire related)-img_1050.jpg   Need some advice.... (wheel/tire related)-img_1053.jpg   Need some advice.... (wheel/tire related)-img_1054.jpg   Need some advice.... (wheel/tire related)-img_1049.jpg
Old 09-26-11, 04:31 AM
IXI187IXI
IXI187IXI's Avatar
245/35 is too big for the front.
there should really be a sticky about this
Old 09-26-11, 08:42 AM
designo
designo's Avatar
Depends on the offset really, I think 245/35's and 275/30's should be fine!
I'd run 30's and 25's if the offsets were more aggressive.
Old 09-26-11, 01:34 PM
msgs350
msgs350's Avatar
245/30 and 285/25 is spec
245/35 or 235/35 and 275/30 is fine
i run 225/35 and 265/30-20 on my AWD but its lowered on DF210's. Rims are 20x8.5 +40 and 20x10 +40
Old 09-26-11, 05:40 PM
lkapimp216
lkapimp216's Avatar
ideal spec would be 245/30 and 285/25 peple complain about rubbing issues alot when they run the overspec tires if you wanted to run a 35 series should have stuck with 19s
Old 09-26-11, 07:20 PM
Mase09
Mase09's Avatar
sorry to highjack, what would be the ideal tire size for an AWD? if im planning on gettting 20's Staggered ?
Old 09-27-11, 05:48 AM
lkapimp216
lkapimp216's Avatar
The ones I suggested, those sizes are extremely close in overall diameter and thats what needs to be spot on with the awd.
Old 09-27-11, 06:00 AM
IXI187IXI
IXI187IXI's Avatar
245/35 is ok to use but more than likely on sharp turns or with the wheel all the way turned, the tire will rub.
Old 09-27-11, 08:28 AM
designo
designo's Avatar
This is the first time I see a 9" front and 10" rear! Usually they are 8.5"/10" or 9"/10.5"
Old 02-16-12, 06:52 PM
Lexiss_sc430
I know, these are a old school set, 8.5 would have been better for me but I have to make these 9's work.
JcISF
IS F (2008-2014)
52
03-18-15 10:09 AM
UGKkllr
03-29-14 11:09 AM
Outrage
07-15-13 03:24 PM
JockMe
04-06-11 03:15 AM
tafadzwa
Wheels, Tires & Brakes Forum
11-13-08 06:22 PM
Quick Reply: Need some advice.... (wheel/tire related)
