best pads
Old 08-12-11, 07:32 AM
gridlock13
gridlock13's Avatar
Originally Posted by GS350Lexus
Akebono pads are very dustless, if you drive for a week it will be covered in very light dust color which isnt even that noticable. Where oem or the red stuff pads i got know every day or 2 looks like a mercedes with oem pads. The squealing sound you get would be the shim kit. I had my oem shim kit on akebono's and at end of its life it started squealing because of the shim kit. I suggest using the kem akebeno shim kit thats already on it.
are u sure it's because of the kit and not the metal tab that indicates low pads?
Old 08-12-11, 12:42 PM
GS350Lexus
GS350Lexus's Avatar
^Yes i still had few x,xxx miles left on them.
Old 08-13-11, 07:49 AM
steviej
steviej's Avatar
Akebono brake pads, tirerack.com.
yep. Akebono ceramics from www.tirerack.com
Side note: Akebono makes Toyota's pads.
Old 08-13-11, 09:21 AM
yiannos63
yiannos63's Avatar
The best pads for your Lexus is OEM, Akebono are great for dust but they don't give you the stopping distance, check out their rating at tire rack, they are rated 2 out 5, OEM you can never go wrong, you get the dust but better safe than sorry
Old 08-13-11, 11:05 AM
arnieosp
arnieosp's Avatar
Originally Posted by yiannos63
The best pads for your Lexus is OEM, ............... OEM you can never go wrong, you get the dust but better safe than sorry
Agree 100%. Except my pads were replaced at 6K miles under TSB for dust problems and I have no dust. When they get worn out, I'll replace them with same pads.
Old 08-13-11, 01:47 PM
Bavaria
Bavaria's Avatar
Also had my pads replaced 6k mile ago under TSB - no dust or squeaks. Will use OEM for future replacements.
Old 08-18-11, 08:56 PM
kenv
kenv's Avatar
Default brake question
2008 GS; 48k miles, currently on 3rd set of front brakes. Most recent set was replaced due to the squeal at low speeds. There are producing no squeals and very low dust, but when applied at 70+ mph I feel a "groaning" when applied. The car stops straight and no wobble in the wheel. I wish I could describe better, but its sounds like their is excessive friction. Also, after being washed (once a week) the braking at high speeds is very smooth, but then the problem comes back. Any opions?
Old 08-19-11, 07:44 AM
jtrue28
jtrue28's Avatar
sounds like your rotors are the problem.
Old 08-20-11, 12:20 PM
johnnunez2
johnnunez2's Avatar
i went with ebc red stuff, i was going to go with akebono but i dont like the idea of less stopping power. plus i found the set online for 150+ shipped. i think it was like 10 or 15% off at another website.autoshephard.com theres a discount on all ebc products.. ill try these out this time. i do have another question though, what service does my car need at 60k miles?
Old 08-20-11, 12:26 PM
johnnunez2
johnnunez2's Avatar
i often brake hard so need something that will respond well. lol if anyone needs brakes you should check them out unless you can get it cheaper.
Old 08-21-11, 09:05 AM
JasGS350
JasGS350's Avatar
I too have this problem sometimes and I just replaced my rotors with brand new power slot rotors. So, I don't think its his rotors if I'm experiencing the same problem with brand new rotors. It doesn't happen all the time but it is noticeable when it does happen.
flektone
09-17-16 07:23 AM
Ab423
12-12-15 11:50 PM
TrojanUAE
LX - 3rd Gen (2008-2021)
11-08-12 11:31 AM
ls1muscle
Suspension and Brakes
09-25-12 12:36 PM
LEXX135
16
09-16-12 10:27 PM
Quick Reply: best pads
