Intermittently stuck shift solenoid - 06 GS300
Old 02-11-13, 01:42 PM
Pastordrj
Pastordrj's Avatar
Default thanks for support lexus atlanta technicn
thanks so much i will get on it right away,,,,,
pastordrj
Old 03-27-14, 01:50 PM
bziegl
bziegl's Avatar
Originally Posted by NAZTY97
Ok... after doing a lil bit of research, I see other older models have suffered this problem, on occassion. My car does it every so often... gears 4,5, and 6 sometimes don't work because the car won't shift past 3rd, or sometimes 4th...
this is annoying as hell that a Lexus would have these kind of problems,... the car does have 161k miles on it, but nonetheless, seems rather disappointing.
Does anyone in the Houston area know a tranny specialist that would feel comfortable working on a newer model lex, and capable of replacing the solenoids??
Does anyone know where to get them?
What did you end up doing? I have the same problem.
Thanks!
Old 06-29-14, 02:37 PM
johnnyslyw
johnnyslyw's Avatar
So what was the outcome of all this im having the exact same problem!!!
Old 06-30-14, 12:22 PM
sirblinks
sirblinks's Avatar
I had the same issues, ended up rebuilding my transmission. FML
Old 08-12-14, 05:11 PM
iamjosan
iamjosan's Avatar
I've been driving my mom's GS300 and it won't shift out of 2nd. Time to get my G35 up and running.
Old 08-12-14, 06:40 PM
BinaryJay
BinaryJay's Avatar
It seems like too many people in the US took Lexus seriously when they said don't change the transmission fluid... you really have to wonder what the reasoning is when Lexus Canada says change it every 60K miles. And yes, you certainly can change it I have already changed mine once and will do it again soon. It costs so little that I really see no reason not to have it done far more often than even Lexus Canada says. I think I paid Toyota like $60 last time.
Old 08-16-14, 11:01 AM
NAZTY97
NAZTY97's Avatar
I ended up buying a new transmission.... and from Lexus, I was told this is a sealed system, so was not to be a transmission fluid change.
Old 08-16-14, 05:00 PM
BinaryJay
BinaryJay's Avatar
The only thing sealed about it is that there is no dipstick. Technically, it still has a drain/fill plug and I certainly have had mine changed and honestly does anybody really believe any automotive fluid will last forever, like 150,000 miles+? Even if it still lubricates, it's going to get dirty and collect crud from transmission wearing down.
As usual, a manufacturer's definition of "lifetime" is an arbitrary number that is usually far shorter than how long us, the consumer, would actually like something to last.
Old 08-17-14, 09:44 AM
warandcar
warandcar's Avatar
thats called a LIMITED lifetime fluid change…. i say change it… BINARYJAY is the lexus dealership in canada recommend you changing the fluid at 60K or do you have a different owners manual….?
Old 08-17-14, 10:28 AM
BinaryJay
BinaryJay's Avatar
The service schedule is different in Canada, it is Lexus that madates it be changed every 60K not any specific dealership. It is spelled out clearly on the maintenance schedule lookup via lexus.ca
This link for a schedule for an 06 shows the 60K (96,000 km) service.
http://consumer.xtime.com/menu6/?var...&inframe=false
- Replace Automatic Transmission Fluid
Old 08-18-14, 12:05 PM
warandcar
warandcar's Avatar
thanks for the info...
Old 11-26-17, 06:36 PM
tabitmcl
tabitmcl's Avatar
I purchased a 2006 certified Lexus GS 300 in 2010 and I am having this same problem. The solenoids are getting stuck in 3 & 4 gear.
When I purchase the car I was told my Lexus in Columbia SC that I never have to change the transmission fluid but after reading this and doing some research on the Canada
service information I wish I had never listed to Lexus of Columbia. I have had many problems with this car since purchasing it and I think it had made me turn against this brand.
Can someone tell me if I have the transmission change if it will correct the problem once new fluid gets into the system.
Old 11-26-17, 10:40 PM
ez12a
ez12a's Avatar
A fluid change/flush would be the cheapest option moving forward. It's not a guaranteed fix, but if it does fix it it'll be a fraction of the cost of a replacement transmission. We dont know enough about your car and the work done on it to definitively say a fluid change will work.
Old 11-27-17, 05:58 AM
tabitmcl
tabitmcl's Avatar
$60 sounds cheap because it's a deal system I was told there is not a way to put fluid into the car.
Old 11-27-17, 06:00 AM
tabitmcl
tabitmcl's Avatar
Thank you, I will try it. Toyota and Lexus both told me they would have no why to put fluid into the car the car. It's definitely getting stuck when I'm driving.
Quick Reply: Intermittently stuck shift solenoid - 06 GS300
