anybody runs with 225/35/20 in the front?
Old 05-01-11, 12:44 AM
blacklexgs
blacklexgs's Avatar
Default anybody runs with 225/35/20 in the front?
after i bought a set of 20" rims
i've had a rubbing issue with 245/35/20 all around
so i went back to local rim shop to shape the liner in the back and
replace tire size to 225/35/20 in the front
now i don't have any rubbing issue but i feel the handling is too smooth
does anyone runs the same size set as me?
any command for this set?
one thing i don't understand is
it seems like a lot of people here running with 275-295 in the back
with no rubbing issue but i wonder why i had the issue with 245
is it because of 245/3520?
instead of 245/30/20?
Old 05-01-11, 01:51 PM
justlex
justlex's Avatar
i run 225/35/20 all around with no rubbing of any kind , but am about to switch the rear tires to 255/30/20 , hopefully it wont start problems when i do tht
Old 05-01-11, 02:58 PM
Mesca
Mesca's Avatar
You say the handling is too smooth like it's a bad thing! And yes 245/35/20 rubs because its over 3% over stock diameter. 245/30/20 doesn't rub.(on an 8.5 rim width anyway). I'm using 235/35 right now and once it's worn out I'm moving onto 225/35 next!
Old 05-01-11, 03:08 PM
ekim
ekim's Avatar
Mine is 225/35/20 and 255/30/20. No problems at all drives fine.
Old 05-01-11, 06:19 PM
LexFather
Guest
Posts: n/a
Did you mention the wheel width?
Less wide tires are actually less prone to hydroplane and they will make the car feel lighter. There is the same power but less contact patch so it may seem more fun and easy to slide the rear out. However at high speeds the car will seem less stable since there is less tire on the road.
Old 05-01-11, 06:36 PM
msgs350
msgs350's Avatar
Im running 225/35/20 (20x8.5 +40) Continental DWS on the front to match 265/30/20
(20x10 +40) in the rear. I have no issues with rubbing olowered on Tanabe DF210 springs. I feel the Continental tire is a great All-Season tire thats rated for mainly rain and snow, i roll it all year round in Seattle! This is a slightly larger tire compared to the Falken FK452 i had before on these same rims.
Old 05-01-11, 07:47 PM
stvincent
stvincent's Avatar
im running 245/35/20 all around, and i do have some slight rubbing, only when i reverse with wheels turned all the way. i ordered over spec tires because i needed little more protection for my wheels. ur rear rubbing issue is most likely the offset. with coilovers, my rear wheels were tucked in nicely with no gap to spare, and no rubbing issues whatsoever.. front was different story though, there was major rubbing where front bumper and fender meets..
Old 05-01-11, 08:59 PM
blacklexgs
blacklexgs's Avatar
is your car lowered?
Old 05-01-11, 09:03 PM
blacklexgs
blacklexgs's Avatar
I don't know it's kinda more fun to drive in a sense but at the same time with high speed on freeway i feel less safer. I was gonna switch up to 235/35 or 235/30/20 when my front two tires run out lol
Old 05-01-11, 09:04 PM
blacklexgs
blacklexgs's Avatar
is your car lowered? wanna see some pics of your ride
Old 05-01-11, 09:05 PM
blacklexgs
blacklexgs's Avatar
I think the guy put 20x10 all around
You are absolutely right ! the car feels much lighter but at high speeds the car seems less stable wow you know what's up
Old 05-01-11, 09:14 PM
blacklexgs
blacklexgs's Avatar
I gotta ask the guy at the shop about the offset. I also was gonna go for falken fk452 but because of the money issue i had to choose nexen. ALSO! I am planning on lowering my car later with DF210 too but i'm scared to death eversince i've had damn rubbing issue.. u got pic of your ride?
Old 05-01-11, 09:17 PM
blacklexgs
blacklexgs's Avatar
maybe my offset is not the right one because when I had 245/35/20 all around I had major rubbing issue like everytime when I make u turn, drive in and out from garage or shopping center etc.. how did you work on the front?
Old 05-01-11, 09:19 PM
blacklexgs
blacklexgs's Avatar
oh forgot to mention about this..
since this morning yellow and red lights popped "check system" message on
now what? what's is wrong with me?
Old 05-01-11, 09:23 PM
swtjlsy
swtjlsy's Avatar
I treid these on when my wheels came in and decide to go with 235/30 which is the same hieght as the 225/35 and they ride great.
Quick Reply: anybody runs with 225/35/20 in the front?
