jdm puddle light wiring question
Old 04-26-11, 04:34 PM
alwayzspeedin
alwayzspeedin's Avatar
Default jdm puddle light wiring question
i have my jdm puddle lights wires to switch but want it to come on when i walk near my car and wheni unloack the doors...i cant figure out wjere to wire it under the dash..i dont wanna take out my door panels and wire it up directly to the side mirrors leds...i am trying to wire it up in the fuse harness area. right now its wired up and when ever i pop my trunk the puddle lights come on . and the first time i thought i had it right but it only lights up when i open my driver door.???????
anyone have any ideas on proper wiring...the instructions that i got is for a
Is350 and i followed that thinking ill be the same but its pretty much bull**** cause it didnt work
Old 04-26-11, 04:43 PM
Stormforge
executive matchup
Stormforge's Avatar
it should be wired to your dome light i think.
Old 04-26-11, 05:15 PM
alwayzspeedin
i think thats the goal my friend but which wires and where?
Old 04-26-11, 06:29 PM
Stormforge
executive matchup
Stormforge's Avatar
had an installer do mine, so i couldn't tell ya. but if memory serves me right, i believe the dome light wire for the GS is pink. not 100% tho.
Old 04-27-11, 12:23 AM
alwayzspeedin
It's blue and purple wires under drive side dash plug #10
Old 04-27-11, 11:48 AM
tuandang79
tuandang79's Avatar
Tim, its the blue wire.
Its a negative wire trigger. right behind the left panels where the mirror controls and stuff is at. Thin Blue wire (darker blue). use a test light.
I tried calling you but you didnt pick up.
Old 04-27-11, 05:46 PM
alwayzspeedin
It's cool tuan I think your way is different method of hooking it up.
My way works to too. This is how it work now.
1. When I walk up to the car the lights light up slowly
2. When walk away it will dim off slowly
3. At a distance when I unarm my car it will come on slowly
4. When I arm it will dim slowly
5. When I close my door I'll turn off
6. While driving when I hit the on button on the dome light my puddles will come on..no need for a separate switch..
This is how it want it, just like factory ...thanx for the heads up though..
Old 04-27-11, 08:34 PM
tuandang79
tuandang79's Avatar
Yea that's how i hooked up mine. So i took the red and went straight to positive constant and then the dome light is negative so i hooked that up to black wire.. to activate the light.
Either way works. You probably tapped into the white wire with red stripe. Make sure you fuse that sucker because if it blows.. you wiill be replace a big blade of fuse.
Old 05-08-11, 12:41 PM
docfnky
docfnky's Avatar
Can you post some pics of the wire? Can't visualize which wires you're talking about.
macjac69
08-23-14 11:10 AM
HarrierRX300
Lighting
05-18-14 02:36 AM
jimjaix
07-18-13 08:05 AM
alwayzspeedin
12-11-09 04:11 PM
excluesive
09-24-07 09:30 AM
Quick Reply: jdm puddle light wiring question
