20inch rims /turning issues??
Old 03-30-11, 10:21 AM
THE.K.W.C
THE.K.W.C's Avatar
Default 20inch rims /turning issues??
Im looking at getting a set a 20x8.5 /20x10 for my 2006 3GS. my question is this.... Has anyone had any issues with tight/quick turns??? I mean does the large front wheel rub on the inner fender or bottom out??
Old 03-30-11, 10:39 AM
IXI187IXI
IXI187IXI's Avatar
my car is lowered a good bit and i dont rub on turns. you need to get the proper size tires. you need 245/30/20 in the front. most people for some reason do 245/35/20 in the front and they have problems with rubbing on sharp turns.
Old 03-30-11, 11:04 AM
justlex
justlex's Avatar
thank you sir, at last someone answered the question , i am looking at the same dilemma , but now my problem is solved , ii get 245/30/20 up front and 275/30/20 in d rear and i should have no rubbing or bottoming out , thank u soo much once again guys
Old 03-30-11, 11:11 AM
IXI187IXI
IXI187IXI's Avatar
just keep in mind that a 245/30/20 is not the same overall diameter as a 275/30/20
if your doing a 245/30/20 up front, then you need a 295/25/20
a 295 may not fit but the next closest is a 285/25/30
Old 03-30-11, 11:15 AM
justlex
justlex's Avatar
soo with that does the rear rim have to be like a 20x10.5 , or the 285/25/20 will fit a 20x10 , because i live in chicago and we have a nice couple of potholes
Old 03-30-11, 12:36 PM
IXI187IXI
IXI187IXI's Avatar
285/25 will fit on a 10" wide wheel
Old 03-30-11, 01:01 PM
rominl
exclusive matchup
rominl's Avatar
if you have overspec tires up front (245/35/20), then when you do hard lock turns, you might have running on front / rear of the front wheel wells. but it's no biggie, you are going slow anyway
Old 03-30-11, 02:57 PM
Jiggaman54
Jiggaman54's Avatar
I have 245/35/20 tires on my GS and the only time it rubs is when I'm pulling out of a parking spot. Like rominl said, you're going slow anyway.
Old 03-30-11, 03:01 PM
I8ABMR
I8ABMR's Avatar
Do not do 245/35/20. It looks way to chunky and will rub. Dont be afraid of 30 profile tires. They hold up fine. I have a 295/25 on the rear of my LS and have had no issues
Old 03-30-11, 03:53 PM
rominl
exclusive matchup
rominl's Avatar
yes, for some reason why you back up the car, it tends to rub more easily
Old 03-30-11, 04:09 PM
supags
supags's Avatar
Sorry i don't mean to thread jack..how about for 19" rims what you guys suggest I'm buying my rims soon. thanks
Old 03-30-11, 04:57 PM
Jiggaman54
Jiggaman54's Avatar
I agree on this. I'm looking at 30s when i get new tires and lowering the car. The 30s look WAY better.
Old 03-30-11, 05:16 PM
lkapimp216
lkapimp216's Avatar
If you go with 19s you can use a 245/35-19 and a 285/30-19
Old 03-30-11, 06:31 PM
rominl
exclusive matchup
rominl's Avatar
and that's spec diameter so likely no rubbing
Old 03-31-11, 12:24 AM
THE.K.W.C
THE.K.W.C's Avatar
how many mile/km are u boys getting out of a 30 series tire??
Quick Reply: 20inch rims /turning issues??
