Front Axle Bearing / Hub Assembly Failed!
Friends,
On my 2006, GS300-AWD, 89,000 miles:
I’ve been hearing a “chomping” and gentle “grinding” sounds from my front driver-side wheel at all speeds (though louder “whining” at higher speeds). The alignment is perfect and drives well otherwise. Took it to the dealer and they confirmed that it is the driver-side front “Hub and Bearing assembly” that needs to be replaced. The number they gave me for the part is: 43560-30030 but I cannot find it anywhere on the web. Moreover, they want $800 for the job which includes the $335 bearing assembly. I tried finding the right part on the web for less $$$ but am coming up with many different versions and am not sure which one is the right one. Secondly I’d like to do the job on my own (and save the $800) and would like to ask the experts here, how difficult is this job (say on a scale of 1 to 10). I am an electrical engineer and have moderate abilities in mechanics. But I do not know if I need unique tools to do this job, or what steps are required to do this.
1. Can someone please recommend a reliable source (preferably an OEM) and a correct part # where I can get this part.
2. Can someone let me know what would I need to do to (in order) to get this thing replaced.
3. Are there special tools that I need to buy to do this?
Many thanks
Joe
Many thanks
Joe
Friends,
Many thanks
Joe
Many thanks
Joe
Order it online from Sewell, they should be able to help you locate the correct part if you call or email them. You can also get CL pricing if you mention it.
Now I'm just hoping either the other side goes out before the warranty is done (or that it lasts forever... I'll take either way). Fact that one side went bad does not have me very optimistic about it's partner.
I can't give you any specifics but since it's an entire hub assembly that is getting replaced I doubt you need special tools. I have no idea how it could take them more than 3 hours to replace one wheel hub.
Thanks Jay,
I tried Sewell, but they didn't have the part for 2006. I did find a similar part at Lexus of Pembroke in FL., but will have to call them during work hours tomorrow to confirm if its the right part. They had the part for $200; that $135 less than the dealer!
Thanks Jay,
If Sewell doesn't have it on hand they order it from Lexus just like every other dealer. Are you sure they told you they couldn't get it?
did you guys have any vibrations at all? wondering if the vibration without any noise is an indication of bad wheel bearing.
op, you can also try here..
http://www.trademotion.com/partlocat...&siteid=214915
Had bearings go bad a few cars ago on a Ford. I remember, I didn't even notice until somebody got into the car and asked me "Is this thing a V8, it's so loud...".
When they fail completely, your wheel can seize up and if it seizes at speed it will - well, likely snap off your whole axle and make you lose control of the car. Luckily it takes a hell of a long time of ignoring the awful noise for that to happen.
Binary, when you took your car in for warranty work, was your car lowered? Curious if they gave you a bad time for your car being modified. Some dealerships I know try to avoid doing warranty work because they say by modifying the car it voids the warranty.
One way you can diagnose a possible wheel bearing issue is to lift the car and try to wiggle the wheel back and forth on the hub. There should not be any play, if there is, then likely the hub is going south.
Joe
Joe
1) click here looks like you can get the part for about $250. Look at the diagram, you need part #2.
2) there should be plenty diy online. its pretty much the same procedure on each car.
3) i dont think you need any special tools. Ive never changed a wheel bearing but from what i remember there are no special tools involved. could be wrong though.
Wheel bearing replacement is not generally a DIY job. You'll need a hydraulic press to do so. Although you mean be able to just take the knuckle apart and bring it down to a local garage and ask them to press the old bearing out and the new bearing in. This should save you some money.
See attached instructions for front and rear.
